creating my own instrument, need help with amp circuit!
Old 3rd August 2012, 12:23 AM   #1
dataplex is offline dataplex
Default creating my own instrument, need help with amp circuit!
hello
i spent last year building a prototype of an electromagnetic harp, as a part of my final thesis for music college.
the harp is basically an arduino controlled ebow harp, one custom built ebow for each string on the inside.
(sorry about the self image, linked to another site...)
there is atouch capacitance keyboard on a circular walnut case, and it can also run in a generative mode - creating its own music. i was really happy with the outcome...
here is an example of what it sounds like ::
electromagnetic harp test
ANYWAY
i plan on perfecting the instrument with a more powerful circuit, that doesn't distort the signal as much.
the LM386-4n in the ebow schematic i used doesn't make the strings vibrate until the chip basically outputting a nasty square wave. you can really hear the driver coil distortion through the resonance of the strings...
also, the response is terrible. i want each note to have a faster attack and more natural, clear sound to it. for that i need to design a NEW ebow circuit! one that is more clear and more powerful (more output to the 8ohm driver coils).
this is the one i used for the harp mentioned above ::
i was wondering if anyone here could help me out?
id like to avoid heatsinks, as i need to cram at least 26 amp circuits into a wooden box...!
is the TBA 820M perhaps a feasible option?
sorry about the long post, but i really hope someone can help me perfect this project!!! i want version 2.0 to rock your socks off!!!
all the best,
úlfur hansson
ulfurhansson.com
Old 3rd August 2012, 05:55 AM   #2
jcx is offline jcx  United States
if you use linear amps there's little you can do to reduce power dissapation - you have to assume heatsinking of some sort is needed for more than a few W
the literaly cool way to drive is with Class D or PWM type drivers - requires external L,C - unless your driver has enough L of high enough Q
more detail about drive coil impednace, needed drive levels, frequency, would help
9 V battery power may just not do the job
Old 3rd August 2012, 06:32 AM   #3
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
LM380?
http://www.ti.com/lit/ds/symlink/lm380.pdf
Old 3rd August 2012, 10:26 AM   #4
hey
actually the whole system runs on 18v, to get an output powerful enough to drive the strings.
the coils are 2000 ohm humbuckers for pickups, and 8 ohms for the drivers...
any further thoughts?
thanks!
u
Old 3rd August 2012, 04:43 PM   #5
the driver is a coil? - hand wound, or a standard part?
because you can change driver impedance by changing winding turns, wire gage, will act like a transformer to change the relation I,V to draw need power from a given supply V
you may want feedback gain control - digital pots are easily controlled by the uC
a modern implementation could use the ADC, PWM output of the uC, would need a level translator/buffer to get the I,V from the uC PWM drive - but then you need to master more subjects for the analog and digital control
Old 3rd August 2012, 06:18 PM   #6
hey jcx, this is very helpful...
all the coils are hand woven... they look like this :
i didn't count the turns, as i used a power drill to wind them. they measure at 8 ohms.
perhaps they are covering to much space on the bobbin... would a coin shaped coil work better than a cigar shaped one?
Old 3rd August 2012, 08:56 PM   #7
can't tell how exactly those are made - AlNiCo core seems to be commonly used in the patent lit for the magnetic core to have some permability and DC field bias
Ebow Technical Analysis seems to be good for starting the patent search
good pickup design info http://web.archive.org/web/201105250...p_results.html (original site down - go WaybBack Machine)
do you have an idea of the string motion range - how close the sustainer can be, or how big a gap if you use a more efficient magnetic core shape?
creating my own instrument, need help with amp circuit!Hide this!Advertise here!
Creating the 'virtual ground' in a single supply preamp/amp circuit??? DoiNk! Solid State 21 18th September 2016 11:43 PM
Line to instrument level converter :Re-Amp circuit? 0vid Instruments and Amps 7 2nd May 2010 09:02 AM
hifi VS instrument amp Ahmad_tbp Solid State 9 3rd June 2005 07:34 AM
Class D musical instrument amp trouble GTC1010 Class D 6 14th November 2004 10:38 AM
Creating a headphone amp out of existing 2A3 amp arnoldc Headphone Systems 9 30th July 2004 02:53 AM
