transformer question
Old 31st July 2012, 11:33 PM   #1
downhiller2010 is offline downhiller2010  United States
Default transformer question
A friend bought a half built chip amp off ebay that I have been assembling ito a chassis for him. It came with a transformer. the color scheme on it is red, yellow, white, blue and blue. what is what, or how can I test for it?
Old 1st August 2012, 01:12 AM   #2
Minion is offline Minion  Canada
Are those the secondary wires or all the wires ?? Generally there will be 2 or 3 wires that come out of the transformer at a different spot as the rest of the wires , the thicker wires will generally be the primary wires and the thinner wires are the secondary wires ......
can you post the primary wire colors and the secondary wire colors , and maybe a picture ??
Old 1st August 2012, 01:25 AM   #3
Thanks, I actually figured it out. Measured the ohms on the secondary and used the two that gave me a reading and the amp works. I know that was a bad explanation!
Old 1st August 2012, 01:47 AM   #4
I think I have it figured out, measured the two blue secondary wires with an ohm meter and used them. The amp work, plays for about 4 or 5 minutes then starts to clip and then stops playing.
Old 1st August 2012, 01:49 AM   #5
kevinkr's Avatar
How hot is the chip when it quits playing? I'm thinking the internal SOA protection/thermal limiter is kicking in due to inadequate heatsinking.
What is the supply voltage? Is a center tap required or does this amp have an output coupling capacitor?
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 1st August 2012, 02:04 AM   #6
They aren't very hot at all. Its built in an old alexis pro amp chassis so the heatsinks should be plenty big. The supply voltage is 32V DC. Center tap could potentially be the problem. A rough layout of this powerboard is as follows- input ground and input-to four small 1uf wima type caps-4 50v 10,000uf caps-two .22uf film caps-to the positive rail ground and negative rail. I have both amp boards connected to this point.
Old 1st August 2012, 02:15 AM   #7
The supply voltage is not changing at all when the clipping occurs/when the channels cut out
Old 1st August 2012, 04:08 AM   #8
The chip is an LM 3886
Old 1st August 2012, 04:43 AM   #9
kevinkr's Avatar
I'm assuming this amplifier uses a bipolar supply - most LM3886 do and you either need two secondaries or one with a center tap on the winding.
Can you post some pix and carefully make a few measurements of the windings when the transformer is powered.
Old 1st August 2012, 06:31 AM   #10
If any parts of the wiring is not clear from the pictures let me know
transformer questionHide this!Advertise here!
Newbie Question - Power Transformer vs Isolation Transformer SparkyPete Tubes / Valves 10 2nd November 2012 07:13 PM
Question on transformer Buzzy Solid State 10 24th March 2008 01:21 PM
Another transformer question kneadle Chip Amps 12 13th May 2006 09:08 PM
A Transformer question alexmoose Tubes / Valves 8 18th April 2006 02:00 PM
transformer question KCC Solid State 5 2nd July 2002 05:33 AM
