Old 30th July 2012, 10:07 PM   #1
Default USB to power an amp?
Is possible to make an audio amp using power from USB? how much will be max output? :/
Old 30th July 2012, 10:10 PM   #2
I think that USB use 5v and max is 100mA right? its just 0.5 Watts :/
Old 30th July 2012, 10:17 PM   #3
N-Brock is offline N-Brock  United States
N-Brock's Avatar
nope, standard is 500mA but some allow more, (USB 3.0) and some ports like on the macbook air allow less current draw.
Old 3rd August 2012, 01:55 PM   #4
Ouroboros's Avatar
If you use an efficient Class-D amplifier with NFB, and partner it with a switch-mode dc-dc converter that alters its output voltage in response to the envelope level of the signal, you can use the fact that speech and acoustic music has a high peak-to-mean ratio. The output power of the amp + dc-dc converter will have a much higher peak power capbability than the simple USB power source would imply. Obviously you also need a large reservoir capacitor value.
There was a company pushing this approach strongly on here last year.
usb power supply for audio tze-hao yen Power Supplies 1 19th June 2012 09:47 AM
USB Power Isolator johnmarkp Digital Source 2 24th March 2012 05:03 AM
usb power noise filtering bmx Power Supplies 19 16th May 2010 07:00 PM
USB power musicfan_cbs Digital Line Level 1 30th March 2010 10:06 PM
USB powered NOS USB DAC with built-in headphone amp dsavitsk Digital Source 15 10th August 2006 06:11 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
