Current source on 3886 mute pin
Old 28th July 2012, 04:51 PM   #1
Michael Bean is offline Michael Bean  United States
Michael Bean's Avatar
Default Current source on 3886 mute pin
Hi All...
I was just sittin' here idling away some time when outta nowhere this question pops into my brain; since I don't normally use the mute function on a LM3886, would there be any audible benefit to using an active current source instead of the usual resistor?
Any thoughts?
Mike
Old 28th July 2012, 06:09 PM   #2
diy_audio_fo is offline diy_audio_fo  Italy
Originally Posted by Michael Bean View Post
Hi All...
Any thoughts?
Mike
Look at
http://www.rane.com/pdf/old/ma3sch.pdf
the schematic of MA3 amplifier by Rane (Rane Corporation)
Old 28th July 2012, 07:03 PM   #3
Thanks, but that doesn't really answer my question whether or not there would be any audible benefit to doing it. I suppose I could get off my lazy butt and try it, but I thought I'd see if anyone here has already tried it.
Mike
Old 28th July 2012, 08:45 PM   #4
djoffe is offline djoffe  United States
At least by straightforward simulations and thought experiments, there is no benefit to a current source on the mute pin. Having said that, I use a current source on the mute pin in my products...
for example, take a look at this assembly manual, the schematic one page from the end....Q2, D3, and R6 are a current source for the mute. But, if you look at the schematic of the LM3886 internals, it just switches an internal current source. I can't see any real difference, assuming responsible design.
http://www.updatemydynaco.com/docume...ualRev2.08.pdf
Old 29th July 2012, 03:21 PM   #5
Hi djoffe,
Yeah, I took another look at the data sheet and it appears you're right, there's probably nothing to gain by going active there.
So once agian, no marching bands or awards for my great ideas! Oh well
Mike
Current source on 3886 mute pinHide this!Advertise here!
Can mute pin on LM3886 (etc.) eliminate popping? cm961 Chip Amps 14 22nd January 2018 02:43 AM
help regarding tda7265 mute pin SHYAM078 Chip Amps 6 30th January 2010 03:25 PM
LM3886 - regulator on the mute pin ? ash_dac Chip Amps 8 2nd September 2006 12:28 PM
Need to connect mute pin on 3886? Hybrid fourdoor Chip Amps 5 24th November 2003 02:07 PM
LM 3886 gainclone & mute palesha Chip Amps 1 27th May 2003 09:11 AM
