My_Ref Fremen Edition RC - Build thread - Page 94 - diyAudio
Old 11th February 2013, 09:58 PM   #931
No 4 is offline No 4  United States
While on the topic of C13, has anyone mounted these caps off the board and retained the usage of the in/ground molex connector by way of a jumper in the caps inboard position? I am considering doing this, but I have concerns about the jumper becoming an antenna. If any of you have done this successfully or unsuccessfully your input would be appreciated. This would greatly simplify the process of auditioning different C13 caps in a finished enclosure.
Will.
Old 12th February 2013, 06:06 PM   #932
Reality first!
ClaveFremen's Avatar
I would exclude it at all...
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Old 24th February 2013, 08:51 AM   #933
voxxonline's Avatar
Send a message via Skype™ to voxxonline
Found one really nice enclosure- kenwood trio m1a power amp.
It is good looking body, but my worry is heat control.
As my speaker low sensitivity I need more sinking surface.
Can I use longer heatsink inside the enclosure and phisically connect it to enclosure to dissipate heat or I can cause too high working temperature inside ?
How to find time to finish my projects ?
Old 24th February 2013, 09:17 AM   #934
Reality first!
The original herstsink is still inside that chassis?
If so use that HS and don't worry, it will probably be more than adequate.
Dario
Old 24th February 2013, 09:29 AM   #935
voxxonline's Avatar
Dario I should stop asking and asking and asking I d better save my questions for a build phase :/
Thank you very much indeed
It is fully working amp, comes with pre as well and for the price I cannot get it better .. so pre can be stripped off the internal parts and used as my own pre. They are same series so match the size and shape, so could be a good visually.
Old 24th February 2013, 09:37 AM   #936
bcmbob is offline bcmbob  United States
It appears the top is an open grid. Are there vent holes on the bottom? Might not even need them with such an unrestricted top.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 24th February 2013, 09:52 AM   #937
voxxonline's Avatar
There are holes for sure+ alu heatsink.
Old 24th February 2013, 10:49 AM   #938
Bob M.
Old 24th February 2013, 12:29 PM   #939
SteB is offline SteB  England
Hi Bob , did you try your linuxguru Lf01 module in this board aswell ?
Old 24th February 2013, 12:41 PM   #940
Hi SteB, No I didn't. As I remember Siva and Dario were exchanging information back then and the concepts were incorporated into the FE. Also, remember the relevant functions there are SMD in the new design.... the socket doesn't exist on the FE.
Dario can explain better than I.
Bob M.
My_Ref Fremen Edition - Beta build/Fine tuning ClaveFremen Chip Amps 1523 1st December 2013 11:16 AM
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 03:38 PM
Last My_Ref Fremen Edition RC boards for sale ClaveFremen Swap Meet 3 4th December 2012 01:04 PM
Hx-Home Edition and Hx Mini Edition will be released December, 24th destroyer X Solid State 54 3rd September 2012 03:44 PM
Canton ERGO RC-1 (frequency room compensation) for RC-L - Schematic wanted tiefbassuebertr Multi-Way 2 20th September 2010 11:20 AM
Copyright 1999-2017 diyAudio
