My_Ref Fremen Edition RC - Build thread
Old 14th January 2013, 12:12 PM   #901
bcmbob is offline bcmbob  United States
Both work well and the choice is dependent on the other equipment in a system. I have had great results with a bare pot, LDR attenuation and an active pre. Your desired SPL and your speaker sensitivity will dictate what you use.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 14th January 2013, 11:46 PM   #902
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Default Any interest for a 'Redux' FE?
In these days I'm playing a bit with a reduced FE board:
My_Ref Fremen Edition RC - Build thread-fremen-redux-edition-jpg
My_Ref Fremen Edition RC - Build thread-my_ref_fre-top-jpg
My_Ref Fremen Edition RC - Build thread-my_ref_fre-bottom-jpg
This PCB differs from the standard FE one in the following:
  • smaller (same dimensions of TP board, it should be a near perfect replacement in actual builds, including drilling and heatsink mounting)
  • same input cap limitation of TP board (22.5mm lead spacing)
  • single bridge, a bit less performing but allow the use of a single transformer for two monoblocks.
  • Not as optimally spaced and optimized as Fremen Edition board.
I've designed it just for fun but maybe it could be interesting for some.
Any comment is welcome...
Dario
ClaveFremen "Bailando Salsa en el Sietch" - For My_Ref FE 12th GB extra boards PM me.
Old 15th January 2013, 09:12 PM   #903
lehmanhill is offline lehmanhill  United States
lehmanhill's Avatar
Dario,
Very interesting. It looks like the big power supply caps are the same size. Is this correct? Personally, I find the single bridge interesting as it makes it easier to bi-amp and tri-amp speakers. The cost of transformers for multiple monoblocks is a bit higher, but they also take up a lot of space.
I have powered both channels of my FE using one transformer with circuits in parallel and without problems. The shorted input hum measured the same and it sounded the same, so even though monoblock is the recommended approach, I am comfortable with either the dual bridge or single bridge approach.
As for the smaller input cap, so far I have been using caps that are either too big (K75) or a very tight fit (K71). I don't mind the cap extending "off-board".
Very nice work. How much different from optimized do you see this board?
Jac
Old 15th January 2013, 09:52 PM   #904
Reality first!
Hi Jac,
No, they're 30mm like in TP boards.
BTW the FE BOM uses 30mm caps so not a real difference.
Good to know
Yes, not a big limitation.
Particularly on the upper left corner area the layout is too much congested, the DC protection circuitry is probably too much near to the input cap.
If this is a problem in a real build... who knows... we should build it and, possibly, measure.
Dario
Old 17th January 2013, 12:02 PM   #905
voxxonline is offline voxxonline  United Kingdom
voxxonline's Avatar
BTW , how much money do I need to save for pcb's or kits (planning holidays soon, need to allocate money) for FE ? What is an estimate ?
How to find time to finish my projects ?
Old 17th January 2013, 09:07 PM   #906
Reality first!
Parts
Around 76€ per board (premium industrial BOM) which can be lowered to 52€ (On a budget BOM)
PCBs
It will depend on the number of partecipants....
50 PCBs (25 stereo kits) -> 18€ each
100 PCBs (50 stereo kits) -> 14€ each
200 PCBs (100 stereo kits) -> 13€ each
300 PCBs (150 stereo kits) -> 12€ each
400 PCBs (200 stereo kits) -> 11€ each
500 PCBs (250 stereo kits) -> 10€ each
These prices are an estimate for a single PCB, they include 1€ donation to DIY Audio and PayPal fees, they're subject to change.
Dario
Old 18th January 2013, 05:23 AM   #907
voxxonline's Avatar
Thank you
Old 29th January 2013, 08:41 AM   #908
atupi is offline atupi  Romania
Worth spending extra 100Euros for two R-core's 120VA 2x24v ?
Now i'm using two toroids 250VA each.
Any body who moved from toroids to R-core can share some impressions ?
Rega RP-1/Simplistic RIAA by Salas/ DCB1 clone/ MyRef Fremen Edition/FC-100/ XTZ 99.26 MkII speakers
Old 4th February 2013, 04:43 PM   #909
No 4 is offline No 4  United States
Default update
I am almost ready to finally power up these boards, but I am waiting for some rikens from parts connexion so I had a little spare time this week. I decided to do a little enclosure work. Most of what I have put together so far is from parts and pieces that I have laying around, except the copper. I had to run to the hardware store for it.
Here are a few blurry cellphone pics..let me know what you think
Old 4th February 2013, 07:57 PM   #910
Reality first!
Any body who moved from toroids to R-core can share some impressions?
IMHO yes, my 120VA R-Cores sound fuller and more powerful than my 225VA Toroid toroids.
But it seem I'm the only one that made a comparison...
Wow! Impressive work!
If' you're asking about layout I think it's pretty good very similar to the one I'm using.
I would, BTW, consider a plain Furutech gold plated inlet in place of the filtered one I can see in pictures.
Dario
My_Ref Fremen Edition RC - Build threadHide this!Advertise here!
My_Ref Fremen Edition - Beta build/Fine tuning ClaveFremen Chip Amps 1526 8th October 2017 03:03 PM
Hx-Home Edition and Hx Mini Edition will be released December, 24th destroyer X Solid State 57 1st June 2017 05:05 PM
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 03:38 PM
Last My_Ref Fremen Edition RC boards for sale ClaveFremen Swap Meet 3 4th December 2012 01:04 PM
Canton ERGO RC-1 (frequency room compensation) for RC-L - Schematic wanted tiefbassuebertr Multi-Way 2 20th September 2010 11:20 AM
