My_Ref Fremen Edition RC - Build thread
Old 26th December 2012, 12:55 AM   #871
lehmanhill is offline lehmanhill  United States
lehmanhill's Avatar
Default Still off topic
Thanks Bob,
I didn't see the first screen you mentioned, but this is an attempt to attach something. I think it worked. Thanks.
As for your article, yes, it is essentially the idea. I'm using an accelerometer instead of dual voice coils. The advantage is that a bass speaker has a lot of distortion due to mass and suspension effects. A feedback subwoofer reduces the distortion significantly, sometimes by as much as 10 or 15 dB. Essentially, the feedback system measures the difference between the input signal and where the speaker coil moved. The power amp forces the speaker to move where it is supposed to be. The result is cleaner bass.
My father built one in the mid-80's and published an article in Speaker Builder, although companies like Velodyne sold very similar subwoofers before that. If my current project works, I'll have to do a forum project on the subject.
Old 26th December 2012, 01:01 AM   #872
bcmbob is offline bcmbob  United States
Worked great. Very clear and quite impressive. You may be organizing another group buy in your near future.
That first screen doesn't show till you select "Advanced Mode" near the bottom of the page.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 26th December 2012, 09:28 PM   #873
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Originally Posted by lehmanhill View Post
I've been busy designing an upgraded signal board for my feedback subwoofer. I took suggestions from on components from Dario, gleaned pearls of wisdom from Dario, Andrew, and Tom, and studied the FE RC and other designs to come up with a board design. It just arrived as if a Christmas present.
Wow Jac!
Really nice!
Dario
ClaveFremen "Bailando Salsa en el Sietch" - For My_Ref FE 12th GB extra boards PM me.
Old 27th December 2012, 01:25 PM   #874
lehmanhill's Avatar
Dario,
Thanks and thanks for your suggestions. I really did learn a lot from the FE and put those ideas into this board.
Jac
Old 27th December 2012, 05:28 PM   #875
Reality first!
You're welcome
Dario
Old 28th December 2012, 01:46 PM   #876
lehmanhill's Avatar
Question A little off topic
Has anyone ever tried to solder a component lead that doesn't want to wet with solder? If so, what can you do to correct this? I am updating some small capacitors in my subwoofer amplifier with some styrene capacitors and the solder won't stick to the leads. The parts come from Parts Connexion, so they should be reputable parts.
Jac
Old 28th December 2012, 02:32 PM   #877
Have you scraped the lead with a razor or exacto blade. I have a very small file and emery paper right next to the solder station. Radio shack was notorious for that problem. Maybe just shoot off a message to the seller.
Bob M.
Old 28th December 2012, 03:04 PM   #878
lehmanhill's Avatar
Thanks Bob,
I had not run into that problem before. I had thought of trying to file it, but these are really thin, really flexible leads and I couldn't get it to stay still. The emery paper did the trick. Thanks again.
Jac
Old 28th December 2012, 03:07 PM   #879
Bob M.
Old 29th December 2012, 09:25 AM   #880
grigore is offline grigore  Romania
grigore's Avatar
Send a message via Yahoo to grigore
Helo Clave!
Did you compared the two amplifiers, yours against the Penasa?
I have found the Penasa amplifier very good sounding but the sound is a bit dry comparing to other solid states desings.
Any thoughts form you in this matter is highly appreciated!
Thanks!
Today is better!
My_Ref Fremen Edition RC - Build threadHide this!Advertise here!
My_Ref Fremen Edition - Beta build/Fine tuning ClaveFremen Chip Amps 1526 8th October 2017 03:03 PM
Hx-Home Edition and Hx Mini Edition will be released December, 24th destroyer X Solid State 57 1st June 2017 05:05 PM
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 03:38 PM
Last My_Ref Fremen Edition RC boards for sale ClaveFremen Swap Meet 3 4th December 2012 01:04 PM
Canton ERGO RC-1 (frequency room compensation) for RC-L - Schematic wanted tiefbassuebertr Multi-Way 2 20th September 2010 11:20 AM
