My_Ref Fremen Edition RC - Build thread
Old 11th December 2012, 10:39 AM   #851
R.I.P.
Ah,
This is what I brought up a long time ago.
Probably not this Thread.
The resistors must be right next to the -IN & +IN Pins.
Is Atupi reporting that he has moved the resistor closer to the -IN Pin?
And the result is improved sound quality?
Is he reporting a change to the value of the RC time constant?
Or, has he retained the 86ms RC? 390r & 220uF = 86ms
regards Andrew T.
Old 11th December 2012, 10:46 AM   #852
ClaveFremen is online now ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
KSTR's suggestions should have the goal of 'achoring' one of C9's plates to ground so to pickup less noise.
Not exactly, the RC boards have the option to mount C9/R10 in both ways.
Yes, the sound subjectively improves.
Only positions are swapped, values are My_Ref's default ones.
Dario
ClaveFremen "Bailando Salsa en el Sietch" - For My_Ref FE 12th GB extra boards PM me.
Old 11th December 2012, 10:52 AM   #853
atupi is offline atupi  Romania
Thanks Dario for clariying the discussion.
Old 11th December 2012, 11:19 AM   #854
R.I.P.
Does swapping the locations of C & R put the resistor closer to the -IN Pin?
I think the answer is "yes".
I do not agree that anchoring one of the capacitor plates to Signal Ground has a more significant effect. I would argue that the anchoring has an insignificant effect.
I would also argue that a bigger effect would be brought about by physically moving the resistor to be actually on the -IN Pin rather than 15mm away from it.
regards Andrew T.
Old 11th December 2012, 12:05 PM   #855
Reality first!
Absolutely.
I don't know but also Mauro found some merit in it.
Can you elaborate a bit?
You're welcome
Dario
Old 11th December 2012, 12:26 PM   #856
R.I.P.
the -IN Pin and to a lesser extent the +IN pin are very suceptible to parasitics, especially capacitance.
The further away the resistor, the longer the trace (and component if swapped the wrong way around). That longer trace has more parasitics than a 1mm trace to an adjacent resistor.
That is the problem that must be avoided in laying out any opamp or power amp traces.
Minimise parasitics on the +IN and -IN Pins.
I am sure I have explained this more than a few times and I am also pretty sure I have argued this on a MyRef Thread.
regards Andrew T.
Old 11th December 2012, 12:59 PM   #857
Reality first!
Sure, now I understand, thanks
My_Ref Fremen Edition RC - Build thread-my_ref_fe-rc-pcb-jpg
I've taken it in in account (see the IN- trace) but it's more difficult for IN+, what would you have done differently?
Dario
Old 11th December 2012, 01:41 PM   #858
R.I.P.
I can't make out the traces well.
But I read it as capacitors near the -IN & +IN Pins.
It should be resistors next to the Pins.
100r, or 200r, smd at the Pins or under the PCB using PTH for shortest (pin to resistor) routes would allow anything to be hung on the other side of the resistors.
regards Andrew T.
Old 11th December 2012, 01:52 PM   #859
Reality first!
I understand...design choices are often compromises.
Dario
Old 14th December 2012, 12:30 PM   #860
dtses is offline dtses
no updates for 3 days, let me fix that...
at last, I have added copper shields, a grounding wire and desoldered few sockets! WOW...The sound has dramatically improved and the soundstage became extremely wide and deep, moreover, I felt as the output power has doubled or even more kidding! no improvements here, it's already good and no hum from toroids as I reported earlier, so just aesthetic addons.
some pics below:
My_Ref Fremen Edition RC - Build threadHide this!Advertise here!
My_Ref Fremen Edition - Beta build/Fine tuning ClaveFremen Chip Amps 1526 8th October 2017 03:03 PM
Hx-Home Edition and Hx Mini Edition will be released December, 24th destroyer X Solid State 57 1st June 2017 05:05 PM
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 03:38 PM
Last My_Ref Fremen Edition RC boards for sale ClaveFremen Swap Meet 3 4th December 2012 01:04 PM
Canton ERGO RC-1 (frequency room compensation) for RC-L - Schematic wanted tiefbassuebertr Multi-Way 2 20th September 2010 11:20 AM
