My_Ref Fremen Edition RC - Build thread
Old 6th December 2012, 01:51 PM   #821
bcmbob is offline bcmbob  United States
How's This: A gainclone relates to a MyRef, as a go-cart relates to a sedan. They both have a gas engine and four wheels, but.... ????
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 6th December 2012, 02:01 PM   #822
badrisuper is offline badrisuper  India
Hi All,
I have been running my FE for atleast 5 hours a day. It sounds so so good. I have only 2 amps I heard so far and I posses. One is my Onkyo 5008 receiver and MyRef. My setup is Marantz CD53(Modded) -> MyRef -> Monitor Audio. I like it very very much. I have a question, so far MyRef has around 50+ hours burn in time. Can I expect more improvement in sound wise after some hours of component burn in? I am rising this question because the lower frequency which I able to hear from Onkyo 5008 setup, not able hear in MyRef setup. Please clarify me.
Badri
Old 6th December 2012, 02:10 PM   #823
udailey is offline udailey  United States
Passive Aggressive
Are you sure the Onkyo is feeding straight through or is it boosting the bass? Obviously no tone controls on the MyRef.
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 6th December 2012, 02:21 PM   #824
Originally Posted by badrisuper View Post
.....................because the lower frequency which I able to hear from Onkyo 5008 setup, not able hear in MyRef setup. ..................
Originally Posted by udailey View Post
Are you sure the Onkyo is feeding straight through or is it boosting the bass?...............
Yes, a very valid question !
Is it a bass boost problem, or a bass cut problem?
Bass boost can also be brought about by adjusting the damping factor seen by the speaker.
A higher source impedance tends towards increasing the output around a narrow band of frequencies.
Yes, the same bass boost as engineered into the Onkyo/speaker could be obtained by adding a 100milliohm resistor into the output lead of the MyRef/speaker combination.
It may not simply be an amplifier frequency response issue !
regards Andrew T.
Old 6th December 2012, 02:26 PM   #825
Passive Aggressive
I will have to play around with some 25W/25R pots I have and put them in series with my speakers. Fun!
Old 6th December 2012, 02:34 PM   #826
A length of nichrome wire recycled from that infra red heater you were about to throw away. Slide the "tap" along the wire to adjust the added source resistance.
Yet more unhelpful posts?
regards Andrew T.
Old 6th December 2012, 02:55 PM   #827
Bradi, Did you use the Mundorf AG caps? They have a significant impact on bass response.
Bob M.
Old 6th December 2012, 03:23 PM   #828
I have used the full band width option for front speaker in onkyo speaker configuration and kept it in stereo mode and used the audyssey setup configuration. But the sound which i heard may not be boosted, it may be captured or produced in that way in the source.
Old 6th December 2012, 03:29 PM   #829
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Since you're using Black Gates, yes.
They change until 500 hours...
this could be the problem, the audissey EQ do equalize....and should optimize frequency response in room.
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Old 6th December 2012, 03:31 PM   #830
Yes I have Mundorf Mlytic caps. And no doubt sound is superb and bass is excellent. I used to have a long listening session. With MyRef I didn't feel tired, no fatigue which I had from Onkyo. This is a particular scenario, the bass which i heard from onkyo in a particular track that I didnt hear from MyRef.
My_Ref Fremen Edition RC - Build threadHide this!Advertise here!
My_Ref Fremen Edition - Beta build/Fine tuning ClaveFremen Chip Amps 1526 8th October 2017 04:03 PM
Hx-Home Edition and Hx Mini Edition will be released December, 24th destroyer X Solid State 57 1st June 2017 06:05 PM
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 04:38 PM
Last My_Ref Fremen Edition RC boards for sale ClaveFremen Swap Meet 3 4th December 2012 02:04 PM
Canton ERGO RC-1 (frequency room compensation) for RC-L - Schematic wanted tiefbassuebertr Multi-Way 2 20th September 2010 12:20 PM
Copyright ©1999-2017 diyAudio
