| Chip Amps Amplifiers based on integrated circuits |
#811 |
Can you refer a good one? I dont think the volume gone up with minimum increase. Its loud but not that much loud. I will check again.
#812 |
I bought this one. Should be even better then Alps as it's of ladder type, but I didn't compare though have them both.
One bad common thing about China attenuators, is that the 1st one I got couple of month ago was completely defective, the other one had a wrong DALE resistor soldered on both channels. So I had to replace them with Vishay, didn't want to spend another month of waiting for the 3rd one
#814 |
#815 | |
#816 |
I'll admit the Alps Blue and the SMD do sound a little different. Again it's a preference and related components issue.
Bob M. "Arrange Whatever Pieces Come Your Way." |
#817 |
The amps are built and working from September, some photos are attached below.
They are a far cry from the gainclone I had and considering that the power stage is practically the same, I guess the project make a difference. The most obvious aspect is the control of low frequencies that now are more consistent with the rest of the spectrum, before the bass*joined to standing waves of the room, making it sound very artificial. Now the modal resonances remain, but the bass is still nice, however I would add a few pictures with the rock wool to dampen the reverberation of the room. I've attached also a picture with a graph of RT60 of right channel (RT60 is the time required for reflections of a direct sound to decay by 60 dB below the level of the direct sound.) Then I perceived a greater involvement with the voices, thanks the great detail and dynamics. In conclusion, the My_Ref_FE have really satisfied me, the transition from gainclone was not a side-grade, as initially thought. Thanks, Roberto |
#818 | |
Reality first!
thanks for the feedback. ![]() Do you have any pic of the interior or of the build process?
Dario ClaveFremen "Bailando Salsa en el Sietch" - My_Ref Fremen Edition GB Second Run |
#819 |
+1
And is that a horn or TL speaker?
#820 |
I have to agree.I had built a PD 3875 gainclone but the My_Ref_FE just blows it out of the water.Sorry Peter but it just does.
| Last My_Ref Fremen Edition RC boards for sale | ClaveFremen | Swap Meet | 3 | 4th December 2012 01:04 PM |
| My_Ref Fremen Edition - need help on PCB evaluation | ClaveFremen | Chip Amps | 444 | 29th October 2012 11:38 PM |
| Hx-Home Edition and Hx Mini Edition will be released December, 24th | destroyer X | Solid State | 54 | 3rd September 2012 03:44 PM |
| My_Ref Fremen Edition - Beta build/Fine tuning | ClaveFremen | Chip Amps | 1519 | 16th August 2012 04:05 PM |
| Canton ERGO RC-1 (frequency room compensation) for RC-L - Schematic wanted | tiefbassuebertr | Multi-Way | 2 | 20th September 2010 11:20 AM |
