| Chip Amps Amplifiers based on integrated circuits |
#802 |
That one is a little expensive if you don't use it a lot,and you might get a better deal on ebay or Amazon. I suggested it only because SPL (sound pressure level) is easier to interpret. There are standards expressed in db (decibels) the relate to real word situations. Loud, soft and such terms are all relative.
If you choose to, you can correlate your volume settings to a more scientific standard - also keyed to distance from the source of the sound. The efficiency and design of the speakers vary so much, it can be useful to know at what SPL in a given system the clipping occurs. There are also all the lab/hardware devices that can be even more informative - but that's still above my pay grade for now. ![]() It obviously is not something that will influence the operation of the amp, and is completely optional - but is fun to have around.
Bob M. "Arrange Whatever Pieces Come Your Way." Last edited by bcmbob; 3rd December 2012 at 11:59 PM. |
#803 |
Got my curiosity up so I went Googleing for "Software SPL Meter".
Found a couple possibilities: REW - At least it looks impressive. Audio Tool - Android app. I downloaded both and will report in the morning.
Bob M. "Arrange Whatever Pieces Come Your Way." |
#804 |
Any suggestions for the clipping issues?
#805 |
cool
![]() not huge, but noticeable! that is the main point. ![]() Mine 10k log Dale attenuator was set to 15th step out of 23 when I compared the caps. That was quite loud, not 80% of the scale, though more than a half. Do you use linear pot or log? It should be fine with the last one as we don't have linear hearing. Last edited by dtses; 4th December 2012 at 07:23 AM. |
#806 |
Its a linear tracking pot.
#807 |
The Audio Tool app is really quite remarkable. It was nice enough that I upgraded to the paid version ($6.95). More useful real time information than the dedicated RS unit I've been using. I don't own an iPhone or iPad but I'm sure there is an equivalent available.
Just a reference - with JRiver flac files using the program volume control - playing through a Mini2496 DAC - pushing the Sunflower speakers, there is no clipping at max settings. Just very very loud
#808 |
Reality first!
For volume control a log one should be used.
IMHO it explain why your volume goes up so quickly...
Dario ClaveFremen "Bailando Salsa en el Sietch" |
#809 |
It is more likely that the system gain is too high.
A CDP putting out ~2.2Vac @ 0dBfs into an amplifier with 31.77times gain (+30dB) has the potential to give an output of 98Vpk if the amp supply rails were +-105Vdc. Simply ludicrous to expect anything other than "just turned on" when using a normal potentiometer and bonkers to consider a linear law potentiometer. read What is Gain Structure? Last edited by AndrewT; 4th December 2012 at 09:59 AM. |
#810 |
REW (Room EQ Wizard) doesn't download completely in the Windows version. The OSX program is more sophisticated than Audio Tool but requires a mike input. I suspect it could be quite useful for FE builders - specially at the price - FREE.
| Last My_Ref Fremen Edition RC boards for sale | ClaveFremen | Swap Meet | 3 | 4th December 2012 01:04 PM |
| My_Ref Fremen Edition - need help on PCB evaluation | ClaveFremen | Chip Amps | 444 | 29th October 2012 11:38 PM |
| Hx-Home Edition and Hx Mini Edition will be released December, 24th | destroyer X | Solid State | 54 | 3rd September 2012 03:44 PM |
| My_Ref Fremen Edition - Beta build/Fine tuning | ClaveFremen | Chip Amps | 1519 | 16th August 2012 04:05 PM |
| Canton ERGO RC-1 (frequency room compensation) for RC-L - Schematic wanted | tiefbassuebertr | Multi-Way | 2 | 20th September 2010 11:20 AM |
