My_Ref Fremen Edition RC - Build thread
Old 20th November 2012, 07:58 AM   #751
atupi is offline atupi  Romania
The leatest and greatest FE
Old 20th November 2012, 08:19 AM   #752
bcmbob is offline bcmbob  United States
OK, Dario provided a little space to prevent the chip from touching, so if you mounted them correctly (small gap under chip) there shouldn't be interference. Double check the tightness of the LM3886 mounting bolt/nut also.
I have 27 VAC from the 300 VA toroids so yours would appear to be in spec.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 20th November 2012, 09:56 AM   #753
I've checked this aspect and is ok. As i never heard how SPIKE behaves i don't know if my problem is related to Spike protection.
Old 20th November 2012, 11:34 AM   #754
lehmanhill is offline lehmanhill  United States
lehmanhill's Avatar
atupi,
I don't have any personal experience with Spike, but maybe this from the datasheet would help.
"SPiKe protection means that these
parts are completely safeguarded at the output against ov-
ervoltage, undervoltage, overloads, including shorts to the
supplies, thermal runaway, and instantaneous temperature
peaks. "
Just checking, are you using 4 ohm speakers? Others have found that 24 V transformers have too much voltage for 4 ohm speakers and recommend 22 V. I have 4 ohm speakers with a 3 ohm minimum impedance and 22 V transformers. I haven't gotten to full volume, but I play pretty loud and don't have any issues.
I also remember reading a FAQ answer on Twisted Pear where they suggest that the LM3886 has a current limit of about 11 amps. In that case, they were using 2 LM3886 bridged to provide twice the voltage, but were still finding a limit in current.
Jac
Old 20th November 2012, 11:42 AM   #755
lehmanhill's Avatar
Default Early Morning, Bob?
What were you doing up at 3 am?
Anyway, I made another measurement, just out of curiosity. I disconnected the input and shorted it with a clip lead. With the amp turned on, the voltage between safety ground and PGND was:
0.04 mV DC (floating around and at the limit of my VOM)
1.1 V AC
I thought the voltage would be higher since the ground reference through input was disconnected, but the voltage only went up a little in AC.
I wish I knew how this explained your 88 V, but I don't.
Jac
Old 20th November 2012, 02:38 PM   #756
Saw a PBS special where they said Einstein and Edison worked four hours and slept four hours. Thought I'd try it to increase my brain power. So far the only result is dark circles, puffy eyes and a headache.
Guess I'm stuck with RTFM.
Bob M.
Old 20th November 2012, 04:17 PM   #757
badrisuper is offline badrisuper  India
Today I tried to measure values to fix one of the broken channel.
C102 = 1.86 [Floating]
C202 = 14.46
Audio is coming from both the channels. But DC offset to the faulty board is >3v. Any suggestions?
Badri
Old 20th November 2012, 09:16 PM   #758
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
C202 = 14.46
that's the problem... C102 should measure +14.6VDC and C202 -14.6VDC
Take other measures and post them:
Dario
ClaveFremen "Bailando Salsa en el Sietch" - My_Ref FE 12th GB is open
Old 21st November 2012, 05:01 PM   #759
I think i have shorted transistors and the regulator. What if the defined values are not getting? Do I need to change this components?
Old 21st November 2012, 06:55 PM   #760
Reality first!
Yes, probably only the transistor but to be absolutely sure I'd change also the LM317
Dario
My_Ref Fremen Edition RC - Build threadHide this!Advertise here!
My_Ref Fremen Edition - Beta build/Fine tuning ClaveFremen Chip Amps 1526 8th October 2017 03:03 PM
Hx-Home Edition and Hx Mini Edition will be released December, 24th destroyer X Solid State 57 1st June 2017 05:05 PM
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 03:38 PM
Last My_Ref Fremen Edition RC boards for sale ClaveFremen Swap Meet 3 4th December 2012 01:04 PM
Canton ERGO RC-1 (frequency room compensation) for RC-L - Schematic wanted tiefbassuebertr Multi-Way 2 20th September 2010 11:20 AM
