Old 29th October 2012, 07:53 PM   #601
Marra is offline Marra  United Kingdom
What to look for?
Old 29th October 2012, 07:59 PM   #602
bcmbob is offline bcmbob  United States
Could that also indicate a weak or defective relay ?
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 29th October 2012, 08:03 PM   #603
measure the output offset.
Remember when the relay is triggered you must measure to the Main Audio Ground, not the isolated ground connection that has been broken by the open relay.
Old 29th October 2012, 08:09 PM   #604
I had the same problem like relay clicking on and off again and again in one channel, later identified I shorted out one channels speaker channel? Will it cause this problem? I had both boards singing in one speaker terminal and from another terminal the relay click on and off.
Badri
Old 29th October 2012, 08:22 PM   #605
with the chipamp protection active, the chip may be switching ON/OFF. That might trigger the relay detection circuit.
Old 29th October 2012, 11:57 PM   #606
Reality first!
ClaveFremen's Avatar
Originally Posted by bcmbob View Post
Tom, You belong on this thread as much as anyone. The FE is, as I'm sure Dario would acknowledge, an extension of all the work and contributions from a whole lot of folks like yourself.
Hoping to get you and the other "Old Dudes" onboard - hands-on soon.
Absolutely!
Originally Posted by lehmanhill View Post
Dario reminded me that I needed to check orientation. To be honest, I hadn't thought to do that, although I should have. As always happens, I managed to pick the wrong orientation for both the ZN and the True Copper. Of course, I had the right orientation for the K71, so I am batting 1000.
In the end, both the TC and K71 beat the ZN for clarity and image in my system.
I'm happy you found same results.
Originally Posted by Marra View Post
Thanks for the reply Dario.
The LM318 was changed and unfortunately I don't have any spares of the bc639/640's.
You're welcome.
You should try to replace those transistors, you can use easy to find BD139-16/BD 140-16 in place of BC639/BC640.
It's easy to damage them while measuring.
Originally Posted by madisonears View Post
If your relay clicks repeatedly or not at all, you most likely have other problems.
Originally Posted by AndrewT View Post
that sounds like DC detection and intermittent triggering of the relay to protect the speaker output.
Absolutely
H Badri,
so both channels are working if connected (one at a time) with the same speaker terminals?
Dario
ClaveFremen "Bailando Salsa en el Sietch" - My_Ref Fremen Edition GB Second Run
Old 30th October 2012, 01:51 AM   #607
Originally Posted by ClaveFremen View Post
H Badri,
Yes, Dario, will be completing it this weekend. Sings well.
Badri
Old 30th October 2012, 09:49 PM   #608
The saga continues.My friend suggested I replace/resolder D1 which was slightly of square which I did this evening and having powered up all voltages appear ok and there is 4.3mv offset and 14.58v across the relay diode.It has been sat on the workbench/dining table for the past 30/40 mins without anything untoward happening.I think it might be good to go
Old 30th October 2012, 10:15 PM   #609
lehmanhill's Avatar
Marra,
Great news. Here is hoping for stable operation and sweet, sweet sounds.
Jac
Old 30th October 2012, 11:58 PM   #610
Reality first!
Dario
Last My_Ref Fremen Edition RC boards for sale ClaveFremen Swap Meet 3 4th December 2012 01:04 PM
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 444 29th October 2012 11:38 PM
Hx-Home Edition and Hx Mini Edition will be released December, 24th destroyer X Solid State 54 3rd September 2012 03:44 PM
My_Ref Fremen Edition - Beta build/Fine tuning ClaveFremen Chip Amps 1519 16th August 2012 04:05 PM
Canton ERGO RC-1 (frequency room compensation) for RC-L - Schematic wanted tiefbassuebertr Multi-Way 2 20th September 2010 11:20 AM
Copyright ©1999-2013 diyAudio
