My_Ref Fremen Edition RC - Build thread
Old 14th October 2012, 02:48 PM   #491
bcmbob is offline bcmbob  United States
Have you checked under C1 and C2? It will require un-soldering but that is a hidden area also.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 14th October 2012, 03:33 PM   #492
Marra is offline Marra  United Kingdom
The input offset is zero with the input shorted and various load resistors the output still reads 3.5v when the relay clicks in which is after a minute or when I start checking p/s voltages I don't posess a microscope but cannot see any thing untoward using a strong magnifying glass.
Old 14th October 2012, 07:24 PM   #493
R.I.P.
There must be a component or soldering error.
Check the output offset at the 318. That should also be the input offset at the 3886.
Check the value of every resistor while on PCB.
Some will give very odd (low) readings due to parallel paths. These may have to have one end lifted.
regards Andrew T.
Old 14th October 2012, 07:47 PM   #494
Thanks Andrew I'll check things tomorrow.
Old 14th October 2012, 11:11 PM   #495
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Hi Marra,
can you post pictures of your build so we can try to identify the problem?
Dario
ClaveFremen "Bailando Salsa en el Sietch" - My_Ref FE 12th GB is open
Old 15th October 2012, 06:13 PM   #496
I checked the voltages as Andrew suggested and at pin 6 of the 318 I have 0.027v but at the input of the 3886 I'm reading 0.070v this fluctuates slightly
Dario my camera is broken; won't charge for some reason but I will see if I can borrow a friends and post pics.
Old 15th October 2012, 06:46 PM   #497
Forgot to say that these readings are to signal negative.
Old 15th October 2012, 09:50 PM   #498
atupi is offline atupi  Romania
Since i've built MyRefFE i have installed R9-C10 group in the alternate position but today i changed to the original position indicated by Mauro and i must say i like it more.
Much music and i would more stereo image. (at least on the speakers that i have it temporary).
Old 15th October 2012, 10:02 PM   #499
Reality first!
This circuit has no need to be tuned to work, no trimmers or whatever.
If our build doesn't work we made an error:
  • wrong component in the wrong place or incorrectly mounted
  • bad solder joints
  • active parts broken by static.
So I suggest to check first that all parts are mounted correctly and in the right position and reflow every suspect solder joint.
If regulators voltages are correct the usual suspects are R11, LM318 and/or LM3886.
A faulty PCB is unlikely since all boards passed electric test by the manifacturer.
Dario
Old 15th October 2012, 10:05 PM   #500
Reality first!
Thanks for reporting
My impression was the opposite, we'll see what other builders will report.
Dario
My_Ref Fremen Edition RC - Build threadHide this!Advertise here!
My_Ref Fremen Edition - Beta build/Fine tuning ClaveFremen Chip Amps 1526 8th October 2017 03:03 PM
Hx-Home Edition and Hx Mini Edition will be released December, 24th destroyer X Solid State 57 1st June 2017 05:05 PM
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 03:38 PM
Last My_Ref Fremen Edition RC boards for sale ClaveFremen Swap Meet 3 4th December 2012 01:04 PM
Canton ERGO RC-1 (frequency room compensation) for RC-L - Schematic wanted tiefbassuebertr Multi-Way 2 20th September 2010 11:20 AM
