My_Ref Fremen Edition RC - Build thread
Old 14th October 2012, 02:30 PM   #481
Are you confirming you have measured 0.26Vdc (between signal Hot and Signal Return) before the DC blocking cap?
Where is that coming from?
regards Andrew T.
Old 14th October 2012, 03:03 PM   #482
Marra is offline Marra  United Kingdom
Bob;restor values all seem ok and I've triple cleaned the boards and checked for solder links can't see any.
Some of the resistor values don't give an instant value but ramp up to the correct reading.
Andrew; yes its minus .26v which goes down and then back up again and once the relay clicks which isn't straight away I initially get 3.5v on the output and this then slowly drops in value.I havent left it powered up to see how low it gets as I did'nt want to burn anything out.
Old 14th October 2012, 03:04 PM   #483
so you have 3.5Vdc on the output
where is the -0.26Vdc?
regards Andrew T.
Old 14th October 2012, 03:07 PM   #484
Across the input connectors before the input cap connects to the circuit.
Old 14th October 2012, 03:14 PM   #485
if the DC blocking cap is not leaking then the input offset voltage cannot appear across the input.
You must have an error here. Somehow voltage is appearing across Sig to Sig G.
You must find how that is getting there.
regards Andrew T.
Old 14th October 2012, 03:16 PM   #486
Where to look is the question.
Old 14th October 2012, 03:20 PM   #487
study the input with a microscope.
There must be something putting voltage on the RCA side of the DC blocking cap.
Is the input voltage zero when you add a dummy resistor to the RCA socket?
Is the input voltage also zero when you "short" the input socket?
Does the output voltage vary for any of these three conditions?
regards Andrew T.
Old 14th October 2012, 03:26 PM   #488
I am no doubt showing my ignorance here but what value dummy load would you recommend Andrew?
Old 14th October 2012, 03:28 PM   #489
0r0 and 100r and 1k0 and 10k etc.
Get cheap RCA plugs and insert resistors to create your dummy test loads.
Mine are white plastic and easy to write on with sharpie (indelible pen).
regards Andrew T.
Old 14th October 2012, 03:44 PM   #490
Thanks Andrew I'll check that out and see what transpires.
My_Ref Fremen Edition RC - Build threadHide this!Advertise here!
My_Ref Fremen Edition - Beta build/Fine tuning ClaveFremen Chip Amps 1526 8th October 2017 04:03 PM
Hx-Home Edition and Hx Mini Edition will be released December, 24th destroyer X Solid State 57 1st June 2017 06:05 PM
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 04:38 PM
Last My_Ref Fremen Edition RC boards for sale ClaveFremen Swap Meet 3 4th December 2012 02:04 PM
Canton ERGO RC-1 (frequency room compensation) for RC-L - Schematic wanted tiefbassuebertr Multi-Way 2 20th September 2010 12:20 PM
