My_Ref Fremen Edition RC - Build thread - Page 46 - diyAudio
Old 7th October 2012, 06:42 PM   #451
bcmbob is offline bcmbob  United States
DC is usually not at zero at initial power-on. I suspect there may be a cold solder joint along the path. Still need the photos of the underside.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 8th October 2012, 07:43 AM   #452
Reality first!
ClaveFremen's Avatar
Originally Posted by badrisuper View Post
Today I connected MyRef FE, No smoke, relay clicked, Light Glowing, but no sound, how to track what is the error.
OK
How to do measurement.
There are a lot of measure that can be taken... we'll see them as we go on with troubleshooting.
When spike protection will be activated?
It's not your case, IMHO, usually you hear sound when SPiKE triggers.
Is this the way to measure DC Offset?
No, you must select Vdc on the multimeter (mV range)
And One channel is getting warmer when compared to other. Other one is cool not at little little warmer.
I would start checking connections, can you post a pic of the transformer label?
After that you'll check DC offset.
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Old 8th October 2012, 07:55 AM   #453
romvise is offline romvise  Italy
Hi Badri, I'm not a DIY expert, but for know DC (direct current) offset you have to set your multimeter in the correct scale, I see AC (alternate current) in your pictures.
Roberto
edit: Thanks Dario for your support, I'm late
Old 8th October 2012, 08:10 AM   #454
I can't tell what is in C30 from the angle of the photos. Is that another Amtran?
Bob M.
Old 8th October 2012, 03:15 PM   #455
Today I checked again. Both boards are fine. Problem with one connection from volume pot i think. DC offset for one board is 2.7 and another is 6.3. Is that good value. Thanks Dario, bob, Roberto.
Badri
Old 8th October 2012, 04:03 PM   #456
Reality first!
Hi Badri,
DC offset values are fine (if milliVolts ).
So you have sound?
Dario
Old 8th October 2012, 04:23 PM   #457
Yes, Dario I have sound. It sounds well. But I expected more. The problem i identified is one of the transformer. I checked one board at a time using one transformer, it sounds fine. Then connected both the boards to separtate transformer, no sound one board and measured the DC volt, it went high. I dont know what would be the reason. I will post more information later.
Badri
Old 8th October 2012, 04:51 PM   #458
I feel like it sounds little harsh. Though I am using a below average kenwood speakers for testing. I have to test with MA Rx6. Anyone knows what would be the problem with the transformer. Using one transformer the DC Offset it is showing is .452 by setting DMM to 2.
Any idea?
Old 8th October 2012, 05:17 PM   #459
Did you measure the AC output on each transformer loop on both before toroids it enters the amp?
Bob M.
Old 8th October 2012, 07:33 PM   #460
Reality first!
Any idea?
There's no label on the transformer?
Possibly you wired it incorrectly.
Regarding sound It could depend on a lot of things... source, burn-in, some component orientation ( did you turned again R11s?) and so on.
First thing is to have two working modules and listen in stereo
Dario
My_Ref Fremen Edition - Beta build/Fine tuning ClaveFremen Chip Amps 1523 1st December 2013 11:16 AM
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 03:38 PM
Last My_Ref Fremen Edition RC boards for sale ClaveFremen Swap Meet 3 4th December 2012 01:04 PM
Hx-Home Edition and Hx Mini Edition will be released December, 24th destroyer X Solid State 54 3rd September 2012 03:44 PM
Canton ERGO RC-1 (frequency room compensation) for RC-L - Schematic wanted tiefbassuebertr Multi-Way 2 20th September 2010 11:20 AM
Copyright 1999-2017 diyAudio
