My_Ref Fremen Edition RC - Build thread
Old 2nd October 2012, 07:49 PM   #431
Marra is offline Marra  United Kingdom
Even with a magnifying glass I struggled they have a mind of there own.
Old 2nd October 2012, 08:21 PM   #432
PMeade is offline PMeade
Default Status
Well sad to say I have been on hold for the past six weeks dealing with familial obligations. This is hopefully at or near it's end and I can get back to finishing this project. But where I am currently is one board is nearly done being populated. This is my first outing with smd components and it was interesting/fun. I believe all went well but will know for sure once powered up. Component wise I used all suggested best parts from the BOM with a couple of exceptions. For C9 I have the standard BK but it is the 4(?) volt version so I will begin with the Nichicon FG. For C13 I have the K71-4. Transformers are the AN3225 300ma's. If all goes well I will give these a listen in a week or two.
Paul
Old 2nd October 2012, 09:01 PM   #433
bcmbob is offline bcmbob  United States
Thanks for the update Paul. Nobody is pushing here so - - -whatever time it takes. Glad you are making progress.
Dario told me he can tell whenever someone starts the SMDs cause he feels a phantom finger thump in the middle of his forehead. I think it's a Dune thing.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 2nd October 2012, 09:04 PM   #434
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Originally Posted by lehmanhill View Post
How do you start with component choices when you start with a new project? For example, do you just assume that Susumu's are high quality and will be a good choice for SMD resistors? How do you pick?
Absolutely not!
I select listening from a variety of components.
This bouquet of parts is pre-selected according availability from Mouser/PCX/Distrelec/RS Components and sometimes eBay.
Obviously parts with good reports enters the bouquet too.
The one that sounds better become part of the BOM.
Regarding Susumus, which have very good reports, I've compared them to other industrial and audiophile parts and they've come second only to Vishay bulk foil.
Vishays are incredibly neutral, detailed, smooth while Susumus are inferior but not much and with a touch of wamth more.
Do you think, this project will need a little warmth, but mostly needs neutral components? I am curious to understand the start of your process.
I'm not sure to understand.. Do you think some warmth is needed for the FE?
The input cap C13 has a big role regarding warmth, the K71-4 are a bit on the cold side of neutral.
BTW my main goal when selecting parts is neutrality, detail, naturalness, lack of harshness, full fleshed sound.
In the meantime, I learned that there are Fremen script numbers, at least 1 through 6, and a partial alphabet of the Fremen language. Maybe, I should letter the chassis in Fremen.
It would be a cool thing...
Originally Posted by dtses View Post
Finally, the bass issue has been solved
Fine, I'm happy for you
Originally Posted by Marra View Post
Decided that I could'nt wait and a package arrived this morning from Farnell and as todays plans had fallen through I warmed up the soldering iron.
Cool
You guys must have better eyesight and steadier hands than me it took ages to solder the smd's and by the end of the afternoon they were being called more than that.
If SMD soldering took you a couple of hours, you're perfectly average.
Has any one tried Kendiel K05 caps for C101 & C201?
Do you have any of the RJH caps left by any chance Dario?
Sadly, no. But you can buy them directly from Elfa
Kendeill are very well regarded caps, they'll probaly sound great but I never tried them.
I do agree, now I like a lot SMD soldering.
It's a safe and smart approach.
Fine
I'll read your comments with interest.
Dario
ClaveFremen "Bailando Salsa en el Sietch" - For My_Ref FE 12th GB extra boards PM me.
Old 2nd October 2012, 09:08 PM   #435
Reality first!
Do yo mean that headaches I''ve had in these last days are due to this?
I was sure they were due to nicotine abstinence...
Dario
Old 2nd October 2012, 09:12 PM   #436
Don't quit quitting !!! You have the support of us all.
Bob M.
Old 2nd October 2012, 10:14 PM   #437
lehmanhill is offline lehmanhill  United States
lehmanhill's Avatar
Dario,
First of all, sorry to hear about your headaches and other nicotine side effects, but keep the faith. We are with you in spirit.
As for the quote above, I apologize for the confusion. I think the FE sounds fine, just like it is. I am very happy with mine.
My questions about how you choose components was because I am about to start a new crossover and feedback board for my subwoofer. I wanted to learn how you started component selection.
As a one-off board, I want to get good components into it, but probably won't have time to audition as many as you have. Now that you guys have taught me how to solder SMD, I will use SMD components where possible. I was hoping for a short cut to selecting good components, but as you say, it takes a bouquet to get the right ones.
In the meantime, I've already learned a lot about which components to start with. Perhaps, once I have confirmed my component values, I can PM you for suggestions on capacitors and resistors.
Thank you, sensei.
Jac
Old 2nd October 2012, 10:19 PM   #438
Jac, Send madisonears (Tom E.) a PM. He has good first hand experience with an active crossover and the MyRef family. He knows his stuff.
Bob M.
Old 2nd October 2012, 10:26 PM   #439
lehmanhill's Avatar
Bob,
Thanks for the suggestion. I know that Tom knows his stuff.
In this case, I already have an active crossover design that I like a lot. I used SoundEasy software to shape the crossover to match both my sub and my satellites in both phase and amplitude.
The board project is to redo the circuit using better components, power supply, and as a balanced signal. It's kind of like what Dario did with MyRef, just a different part of the chain.
Wish me luck though. There are a lot of things that can go wrong as Tom has already warned me.
Jac
Old 2nd October 2012, 10:28 PM   #440
OK, "Good Luck"
Bob M.
My_Ref Fremen Edition RC - Build threadHide this!Advertise here!
My_Ref Fremen Edition - Beta build/Fine tuning ClaveFremen Chip Amps 1526 8th October 2017 03:03 PM
Hx-Home Edition and Hx Mini Edition will be released December, 24th destroyer X Solid State 57 1st June 2017 05:05 PM
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 03:38 PM
Last My_Ref Fremen Edition RC boards for sale ClaveFremen Swap Meet 3 4th December 2012 01:04 PM
Canton ERGO RC-1 (frequency room compensation) for RC-L - Schematic wanted tiefbassuebertr Multi-Way 2 20th September 2010 11:20 AM
