My_Ref Fremen Edition RC - Build thread
Old 30th September 2012, 10:52 AM   #411
bcmbob is offline bcmbob  United States
Originally Posted by SoIL4x4 View Post
By the way Bob I did finish my cat 5 speaker cables and have to say they do have a positive effect on the sound of my system. The bass is more defined and the highs are crystal clear. Thanks for the heads up.
My fingers just recovered!
Glad to hear you like the cables. They provide a significant improvement at minimal cost. Well worth the effort....... and the sore fingers
Also wanted to add if builders don't want to post their ststus for any reason, a PM to Dario would be great.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 30th September 2012, 11:35 AM   #412
dtses is offline dtses
Originally Posted by ClaveFremen View Post
Which Caddocks? I can't see any in your build...
sorry mixed up with Takmans
Old 30th September 2012, 11:41 AM   #413
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Ah! OK
Then the answer is:
yes, I would replace them.
Use SMD thin film resistors, with a low TCR (<=50ppm)
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Old 30th September 2012, 11:43 AM   #414
Originally Posted by PreSapian View Post
dtes you sound like me when i first started the journey of modding myrefc.
if you're to look at my earliest posts on 'new myrefc' thread, i'm always complaining about lack of bass, much like you.
then after many swapping of components as recommended by dario, i don't remember exactly when and after which swap, but myrefc's bass improved to where now it's simply the best bass i have heard.
thanks mate!
You gave me a hope! will try to replace parts one by one and stick to the BOM then as this is the only option now.
grazie
Old 30th September 2012, 11:45 AM   #415
AndrewT is online now AndrewT  Scotland
I saw recently a Member reporting that all 0.1% tolerance (thin film) smd are metal film and that all 1% tolerance (thick film) smd are metal oxide.
Is this universal?
Does the metal oxide perform sonically as well as the metal film? I am assuming the resistance value is identical.
regards Andrew T.
Old 30th September 2012, 12:03 PM   #416
Reality first!
grazie
Prego (you're welcome)
Please note that it's not easy to find good sounding SMD resistors, I can't guarantee that the ones you'll buy will sound with full bass.
Try to find Nichrome ones
Originally Posted by AndrewT View Post
I saw recently a Member reporting that all 0.1% tolerance smd are metal film and that all 1% tolerance smd are metal oxide.
Hi Andrew,
Really?
IMHO it's a simply absurd generalization.
While most of the 0.1% are thin film or bulk foil, in 1% tolerance thin film, thick films, and metaloxide are all available.
If you trust in this sort of things... no.
Usually Metal oxide sound harsher and less detailed than metalfilms.
Dario
Old 30th September 2012, 12:32 PM   #417
billo44 is offline billo44  United Kingdom
billo44's Avatar
Default Sounds good
Finally got my FE RC build working today....
Shoe-horned into my 'my ref rev C' chassis, and using the obligato input caps and lightspeed passive pre I used in that build. This was mostly because of lack of money, but also means I can compare with my memory of how the my ref rev C ultimate bom sounded last week.
All worked with no hum or problems straight away, measured 13 mV and 16 mV DC R/L at the output.
I will wait a week or so before getting too sentimental, but the sound is already very good after a few hours...
Thanks Dario, it's sounding good!
Bill
Old 30th September 2012, 12:58 PM   #418
Reality first!
Hi Bill,
Good news!
Fine, expect DC offset to lower in some days.
You're welcome.
I've seen you're using a ground breaker to connect PGND to safety earth.
When you can, please, try to disconnect PGND from modules and tell us if you hear a difference (pay attention to soundstage).
Dario
Old 30th September 2012, 02:34 PM   #419
Bill, I can't see where you are getting power for the Lightspeed PS.
Are the large white wires going to the front connected to pots?
Bob M.
Old 30th September 2012, 03:39 PM   #420
billo44's Avatar
Hi Bob,
Power for the lightspeed is tapped from one of the large smoothing caps via a regulator suggested by Regi Regi on the My ref rev C ultimate BOM thread.
That's the brown proto board with five caps center right.
White leads are cheap cat 5 lan cable, I just use one for each channel, going to a headphone socket/switch set up.
It's all a bit patched up and shoddy since I added the headphone output as an afterthought.... still don't have the resistor values right...
Next time!
Bill
My_Ref Fremen Edition RC - Build threadHide this!Advertise here!
My_Ref Fremen Edition - Beta build/Fine tuning ClaveFremen Chip Amps 1526 8th October 2017 04:03 PM
Hx-Home Edition and Hx Mini Edition will be released December, 24th destroyer X Solid State 57 1st June 2017 06:05 PM
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 04:38 PM
Last My_Ref Fremen Edition RC boards for sale ClaveFremen Swap Meet 3 4th December 2012 02:04 PM
Canton ERGO RC-1 (frequency room compensation) for RC-L - Schematic wanted tiefbassuebertr Multi-Way 2 20th September 2010 12:20 PM
