My_Ref Fremen Edition RC - Build thread
Old 31st July 2012, 11:41 PM   #31
lehmanhill is offline lehmanhill  United States
lehmanhill's Avatar
To those of you who used a board (non-conducting chassis) as a test chassis, what did you do regarding PGND? Did you connect PGND to mains ground?
Thanks in advance.
Jac
Old 1st August 2012, 01:42 AM   #32
ClaveFremen is online now ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Hi Jac,
like in the Evolution Rev A I've left PGND not connected.
In my case the amp sound worse with PGND connected to safety ground.
In this moment only transformers' shield is connected to safety ground; when it will be cased also the chassis will be connected to safety ground.
I'm pretty sure that grounding will be one of the more discussed topics in this thread...
Dario
ClaveFremen "Bailando Salsa en el Sietch" - For My_Ref FE 12th GB extra boards PM me.
Old 1st August 2012, 09:05 AM   #33
bcmbob is offline bcmbob  United States
The newer Antek toroids have a "shield" wire that I have connected to safety ground. It doesn't pass through to the amp. The older "standard" toroids and the ApexJr pieces don't have that feature. Just bought my first R-core for a DAC and it has a safety ground also - as noted above by Dario - again tied back to the AC inlet.
I see the shock hazard to be greatest from the power inlet to the trani. Good insulation and lots of heat shrink tubing can deal with that - IMO. The reduced AC voltages from trani to the amp I believe are less of a threat, but even that leg can be well protected from physical contact.
So I guess the two remaining issues are protection of some board components, and how safety ground effects the sound. Does that sound correct? I'm not sure if something like a CL-60 would be beneficial here. I have seen Siva recommend it's use on several threads.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 1st August 2012, 09:10 AM   #34
Reality first!
Bob!
Don't mention CL-60s!
You're risking AndrewT's blaming , if he's back from vacation...
Dario
Old 1st August 2012, 09:30 AM   #35
Oops !
Well, I suspect it may have come up somewhere along the discussion. Have to see what develops.
Bob M.
Old 1st August 2012, 01:44 PM   #36
Reality first!
Default Boards up and running
I've finished my build, both boards are playing music in this moment
My_Ref Fremen Edition RC - Build thread-dsc_0181-800-jpg
I've had some trouble with one module though...
It power up correctly, relay was clicking but it was mute....
Guess what was the cause?
An interesting demonstration
My_Ref Fremen Edition RC - Build thread-dsc_0179-800-jpg
As you can see, thanks to the new eagle object and positioning, there is clearance between board and heatsink.
Dario
Old 1st August 2012, 03:38 PM   #37
No 4 is offline No 4  United States
Dario, are you isolating the ic from the heatsink with anything but the thermal compound? It is hard to tell from the last pic.
Old 1st August 2012, 03:39 PM   #38
Reality first!
I was forgotting DC offset measurements:
6.4mV and 5.8mV
Only thermal compound
Dario
Old 1st August 2012, 03:55 PM   #39
Just to double check - did anyone buy the non-insulated LM3886? I don't know if they are even available new anymore, but could have been purchased on eBay. Those need an insulator. That is what is shown in the photo on post #29.
Bob M.
Old 1st August 2012, 04:45 PM   #40
Reality first!
Default Some addititional notes for builders
For those that bought the ERO kit
Solder the KP1834s as the last parts, after cleaning the boards.
Polystirene is very delicate and I can't find a datasheet to confirm or not they can stand with solvent washing.
Soldering temperature for C101/C201
The thermal pads of both caps need a very high temperature to be be well soldered, I would say around 370-380 C.
Final inspection before powering up
Before powering up inspect all solder joints surrounded by the groundplane to insure joints are exactly on pads without making bridges with the groundplane.
It shouldn't be a problem thanks to the soldermask but it's a cleaner and safer job.
Dario
My_Ref Fremen Edition RC - Build threadHide this!Advertise here!
My_Ref Fremen Edition - Beta build/Fine tuning ClaveFremen Chip Amps 1526 8th October 2017 03:03 PM
Hx-Home Edition and Hx Mini Edition will be released December, 24th destroyer X Solid State 57 1st June 2017 05:05 PM
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 03:38 PM
Last My_Ref Fremen Edition RC boards for sale ClaveFremen Swap Meet 3 4th December 2012 01:04 PM
Canton ERGO RC-1 (frequency room compensation) for RC-L - Schematic wanted tiefbassuebertr Multi-Way 2 20th September 2010 11:20 AM
