My_Ref Fremen Edition RC - Build thread - Page 33 - diyAudio
Old 17th September 2012, 11:38 PM   #321
lehmanhill's Avatar
Dario,
CapXon are 6.3 V.
They are marked NP85deg C, P1230.
Soongsc can send you a datasheet if you are curious.
Jac
Old 18th September 2012, 08:57 AM   #322
atupi is offline atupi  Romania
Jac, what orientation of C9-R10 (390R-220uf) you used, the original one or the the alternate ? Wich one you prefer ?
Old 18th September 2012, 02:53 PM   #323
lehmanhill's Avatar
I went straight to alternate c9 - R10. It sounded so good, I didn't try the original. How about you?
Old 18th September 2012, 08:28 PM   #324
alternate sounds more direct and cleaner, original more subtle. just my 2cents
Old 18th September 2012, 08:55 PM   #325
bcmbob is offline bcmbob  United States
Just Fo The Fun of It - maybe something like this
1. Sealed cooler with internal fins.
2. Heat transfer tape. Leftover from piece bought years ago for computer projects.
3. Aluminum block for chip mounting.
4. Nylon tee.
5. Vinyl tubing.
Used the footprint method to locate mounting screw location. Jut put a little paste (Machinists us bluing) on the chip (with standoffs attached) and pressed it against the HS. Should have thought of that sooner.
For deep threads I ground off the starting taper on a regular tap. Using a drill press assures a 90 degree hole
Messed up the tape lay (its stretchy without membrane covers) on one but the otter was perfect. Clamped overnight for best bond possible.
Hope to be hearing some "Cool Sounds" by the weekend.
PS - Hey metal, I almost bought one of these as you suggested. Definitely smaller and more convenient than liquid nitrogen.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 18th September 2012, 09:51 PM   #326
lehmanhill's Avatar
Originally Posted by ClaveFremen View Post
Interesting... Which voltage rating was the CapXon?
Inviato dal mio LT22i con Tapatalk 2
Dario,
I checked on Mouser for other non-polarized 'lytics that might be interesting. Soongsc has access to the CapXon, but they aren't available from the usual suspects. One that might be interesting was a Nichicon Muse 220uF, 6.3V, non-polarized. The data sheet says it is good for audio. Just a thought.
Jac
Old 18th September 2012, 10:04 PM   #327
I already tested Nichicon Muse BP (non polarized) and it lacks details.
Old 19th September 2012, 01:56 AM   #328
OK you guys. Go ahead and ignore me if that makes you feel good. But when the entire industry adopts the "Bomac Liquid Audio" format for audiophile listening, I won't be bitter that I got zero support from the FE thread members.
That's how you wanna be? So just go on with your own fine selves. I WILL wipe away the tears and carry on as best I can.
Bob M.
Old 19th September 2012, 02:09 AM   #329
No 4 is offline No 4  United States
Bob, dry your tears....I know I was waiting for more info on your plans for your system. Like what are you using to pump fluid? Reservoir? And what about mono blocks? Are they going to share a pump and reservoir? If one circulates better than the other then one may polute the other with heat. What about this?
Old 19th September 2012, 09:27 AM   #330
Reality first!
ClaveFremen's Avatar
And dark sounding too...not my cup of tea...
For sure it's a cool project... don't give up!
Liquid cross-talk?
Dario
ClaveFremen "Bailando Salsa en el Sietch" - My_Ref Fremen Edition Group Buy 10th Run.
My_Ref Fremen Edition - Beta build/Fine tuning ClaveFremen Chip Amps 1523 1st December 2013 12:16 PM
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 04:38 PM
Last My_Ref Fremen Edition RC boards for sale ClaveFremen Swap Meet 3 4th December 2012 02:04 PM
Hx-Home Edition and Hx Mini Edition will be released December, 24th destroyer X Solid State 54 3rd September 2012 04:44 PM
Canton ERGO RC-1 (frequency room compensation) for RC-L - Schematic wanted tiefbassuebertr Multi-Way 2 20th September 2010 12:20 PM
Copyright 1999-2017 diyAudio
