My_Ref Fremen Edition RC - Build thread
Old 30th July 2012, 09:14 PM   #21
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Default First power up
After branching transformers you can fire up modules (be sure they're heatsinked.... ) with all inputs and outputs disconnected.
You should hear relais click, this is the first good news, it means modules are working and no serious DC is present at output.
Keeping modules powered on we then proceed to measure DC offset at output tabs.
It should measures less then 20mV and with shorted inputs less then 10mV.
If relais don't click don't panic, power off modules and ask help on this thread.
Disclaimer
This tutorial it's not the unique way to build the amp and it's not necessarily the best one but it worked for me several times.
Dario
ClaveFremen "Bailando Salsa en el Sietch" - For My_Ref FE 12th GB extra boards PM me.
Old 30th July 2012, 11:36 PM   #22
bcmbob is offline bcmbob  United States
My only suggestion so far is to go through the tutorial several times before starting the build. This morning I sent Dario a PM questioning the "thermals" reference in post #10. He referred me back to post #7 where I had completely blown past the explanation. So be attentive. Don't hesitate to post problems and questions.
I also had mentioned the need for some pre-planning if builders think they will mount the LED on a front panel. Dario made note of that in the thread.
Will read through again tonight, but I can't imagine a more thorough and detailed guide.
It's gonna be great fun and rewarding!
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 31st July 2012, 12:05 AM   #23
lehmanhill is offline lehmanhill  United States
lehmanhill's Avatar
Dario,
If I may suggest, this would be a good time to lay out the alternative build choices in one place;
Optional capacitors
advantage and disadvantage of the C9 - R10 choice
alternative compensation capacitors
orientation of premium parts
That way, everything is together in one place and easy to find.
By the way, the build looks very good.
Jac
Old 31st July 2012, 12:33 AM   #24
No 4 is offline No 4  United States
Originally Posted by lehmanhill View Post
Dario,
Optional capacitors
Jac
And a complete list of locations for sockets. this way a builder could lay out the socketed positions ahead of time and not have to worry about trying to remember the swap locations while populating the board. This way no leads get accidentally trimmed.
I have a list that I have been carrying around in my pocket of the locations that I have identified (it is written on a copy of the pcb) but I am sure I missed a spot or added one.
Old 31st July 2012, 01:17 AM   #25
Reality first!
Optional capacitors
Otional capacitors C102/C202 are there just beacuse there was space for them but I wouldn't use them unless stability problems arise.
The amp sound better without.
Functionally both arrangements are identical but the new one makes the circuit less prone to pickup noise.
To my ears it also sound better...
But experimenting with both arrangements is encouraged to confirm the final choice.
Rev C compensation is the original one developed by circuit designer Mauro Penasa, it's a no brainer and sounds great.
FE compensation has been 'guessed' by me via trial and listen and sound more refined in the high range with a tighter bass and (much) wider and deeper soundstage, LinuxGuru simulations and several months of use proved it's stable.
FE compensation can be considered experimental but it's the one I suggest to use.
Amtrans are oriented exactly like FKP2s
150pF KP1834 have a yellow mark (see picture)
I don't know how much it can be useful since it depends on what you want to experiment with...
BTW
My_Ref Fremen Edition RC - Build thread-sockets-jpg
The area in the cyan rectangle is the most interesting to explore.
The positions that should be socketed for sure are C9 and R10 to determine which C9/R10 arrangement it's the best one.
Builders that don't want to experiment are encouraged to use the alternate arrangement
Dario
Old 31st July 2012, 01:43 AM   #26
Dario, orientation at R13 appears a bit confusing.
Bob M.
Old 31st July 2012, 01:47 AM   #27
Reality first!
It's because R13 can accept both Mk132 an 0309 resistors.
The left orientation is for Caddocks while the right one is for KOAs.
Inviato dal mio LT22i con Tapatalk 2
Dario
Old 31st July 2012, 09:33 AM   #28
Understood.
Bob M.
Old 31st July 2012, 10:41 AM   #29
Here is a note on mounting the LM3886 as shown in post #18. This came up back in the MyRef V1.2/V1.3 threads. Minor alignment problems can be corrected by insuring there is a little stand-off from the board. When making measurements to locate where to drill the hole in the heatsink, a spacer like a matchstick or toothpick will ensure there is some flexibility on the pins - which need to protrude completely through the holes - but horizontal of chip leads should not be flush to the PCB.
Having the standoffs mounted at this step is important. Also try to think about the need for any clearance between the bottom of the heatsink (if needed) and the chassis that will house the amp. Spacers may be useful here also. Dry/cold fit everything before drilling and/or applying solder.
Bob M.
Old 31st July 2012, 11:56 AM   #30
Reality first!
The LM3886 Eagle component I've used in RC boards it's a new one derived from National one, different from all previous, and have exact holes.
It will be easier to desolder the part if needed and LM3886 will slide in without alignment problems.
For the same reason the LM3886 will no more stand up without soldering like in Bob's pictures.
Also I've aligned component so that the LM3886 edge will have at least half millimeter from board's edge so that it should adehere perfectly to heatsink.
Dario
My_Ref Fremen Edition RC - Build threadHide this!Advertise here!
My_Ref Fremen Edition - Beta build/Fine tuning ClaveFremen Chip Amps 1526 8th October 2017 03:03 PM
Hx-Home Edition and Hx Mini Edition will be released December, 24th destroyer X Solid State 57 1st June 2017 05:05 PM
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 03:38 PM
Last My_Ref Fremen Edition RC boards for sale ClaveFremen Swap Meet 3 4th December 2012 01:04 PM
Canton ERGO RC-1 (frequency room compensation) for RC-L - Schematic wanted tiefbassuebertr Multi-Way 2 20th September 2010 11:20 AM
