My_Ref Fremen Edition RC - Build thread
Old 27th August 2012, 08:19 PM   #231
bcmbob is offline bcmbob  United States
I'm using a 3A slow blow and haven't had any problems.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 27th August 2012, 11:28 PM   #232
lehmanhill is offline lehmanhill  United States
lehmanhill's Avatar
I'm using the same as Bob. I have Randy Slone's old book on building power amps. He suggests using both a fuse on the mains side of the transformer, plus one for each rail on the transformer side of the smoothing caps. I've done that in the past, but I'm not sure there isn't a negative effect on sound due to the impedance of the fuse and extra wiring. This time, I just used the mains fuse.
Any other thoughts?
Jac
Old 28th August 2012, 12:23 AM   #233
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Originally Posted by lehmanhill View Post
Any other thoughts?
A fuse fuse on hot/phase is needed for safety.
Value used for gainclones are good also for the My_Ref (FE or not).
They're different for 110V (3A slow blow) and 230V (2A slow blow) for two modules in a single enclosure.
Dario
ClaveFremen "Bailando Salsa en el Sietch" - For My_Ref FE 12th GB extra boards PM me.
Old 28th August 2012, 02:22 PM   #234
romvise is offline romvise  Italy
I'm waiting for a pair of lm318 for solve the problem of first channel, but unfortunately today after one hour of listening, the second channel has stared to playing some bad intermittent distortion.
When I power on the unit, the relay switch on and off after a pair of second.
I've tried to measure DC offset but the value is variable.
Have you any useful tips?
Roberto
Old 28th August 2012, 02:30 PM   #235
Reality first!
LM3886 temperature?
Dario
Old 28th August 2012, 04:08 PM   #236
No, the chassis was near cold and also the chip, but I've found T101 smoking on the pit of the middle leg, I think was dust! after clean DC offset look stable on 5.5mV.
What do you think about the transistor, could it be alive?
Old 29th August 2012, 09:23 AM   #237
Yesterday I've pluged to mains the unit and today all was in order so I connect it to speaker, and all is ok!
Today I've also received the LM318M for the other channel, but I've found a surprise...
The chip don't have the pin orientation sign!!
So I've 50% of possibility to install it in the right way... and maybe I've also to consider Murphy's law...
Roberto
Old 29th August 2012, 09:33 AM   #238
Reality first!
It's not so... you have the dent:
My_Ref Fremen Edition RC - Build thread-lm318m-jpg
BTW it's strange... are you sure that distrelec shipped natsemi part?
Can you see the natsemi logo on chip?
Dario
Old 29th August 2012, 11:24 AM   #239
Thanks Dario, I've found the dent with a lens.
I've bought two National LM318 and, I've just noticed, one has the round sign and the other the dent, both are MWAB LM318M with National logo.
I've substituted the LM318, but DC offset is always 60mV and sometime on start the relay don't wake up. So, the story is unvaried and maybe the problem is elsewhere.
Old 31st August 2012, 09:08 PM   #240
PMeade is offline PMeade
Default C12 position
Well I am finally soldering up the boards. A quick question though. C12 is not a polarized cap correct? That being said is there a preferred installation? I have the Amtrans 73778. In looking at the schematic, polarized cap installations are clearly marked with a + as is the circuit board. However, I noted o's on some of the other cap diagrams on the board. What is this? Clearly a newbie here. Thanks.
Paul
My_Ref Fremen Edition RC - Build threadHide this!Advertise here!
My_Ref Fremen Edition - Beta build/Fine tuning ClaveFremen Chip Amps 1526 8th October 2017 03:03 PM
Hx-Home Edition and Hx Mini Edition will be released December, 24th destroyer X Solid State 57 1st June 2017 05:05 PM
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 03:38 PM
Last My_Ref Fremen Edition RC boards for sale ClaveFremen Swap Meet 3 4th December 2012 01:04 PM
Canton ERGO RC-1 (frequency room compensation) for RC-L - Schematic wanted tiefbassuebertr Multi-Way 2 20th September 2010 11:20 AM
