My_Ref Fremen Edition RC - Build thread - Page 22 - diyAudio
Old 26th August 2012, 08:08 PM   #211
metal's Avatar
of course, music is playing :P
I started winding today, it took me 5 hours to finish it and connect it to the mains, this is my first time building a transformer : )
Old 26th August 2012, 08:11 PM   #212
bcmbob is offline bcmbob  United States
That's quite an accomplishment. What values/rating did you come up with?
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 26th August 2012, 08:13 PM   #213
metal's Avatar
24.6-0-24.6, transformer rated at 180W.
Old 26th August 2012, 08:14 PM   #214
Impressive ! Maybe you found a new side job "Metal's Custom Transformers"
Bob M.
Old 26th August 2012, 08:18 PM   #215
metal's Avatar
It made me too busy today, I did not go to work ; )
It was not easy thu, I had to wind 652 for the primary! My head is glowing @ the moment : )
Old 26th August 2012, 08:29 PM   #216
lehmanhill's Avatar
Relays and LEDs on first power up.
DC offset < 2 mV both sides.
14.55, -14.5 @ C102,C202
Early impression, very detailed, dynamic, very clear.
Before you guys try to politely explain the correct direction for a heatsink, let me explain that my final application of these boards will be mounted vertically on the back of each speaker. In this photo, the test board is tilted about 45 degrees and they seem to run cool enough.
One other caveat. My system runs a feedback subwoofer with an active cutoff at about 100 Hz. I won't have any comments on bass because the sub handles that. In fact, because the FE's have a higher gain than the sub was originally designed for, I actually lost a touch of bass level. I'll clean that up in the next (balanced) version of the subwoofer board.
Old 26th August 2012, 08:33 PM   #217
I thought you were close - my left ear was twitching. Congratulations !
What size transformer are you using? Can you give a little more info in your system. I'm not clear on the connections.
Bob M.
Old 26th August 2012, 08:37 PM   #218
Maybe we can get one more pair today for a triple play !!
Bob M.
Old 26th August 2012, 09:26 PM   #219
Reality first!
ClaveFremen's Avatar
I'm happy
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Old 26th August 2012, 09:38 PM   #220
lehmanhill's Avatar
Talking Smiling all the way!
Very nice. The mid-bass filled in quite nicely with some burn-in. This is a nice combination of detail and full sound. YeeHaa!
I don't have anything really good to compare it to, but so far this is clearly the best my system has ever sounded.
Someone asked for a brief description of each system. Mine is a satellite/subwoofer system. The satellite's are DIY using Dynaudio tweeter and mid-bass. These are powered by the FE. The subwoofer uses an accelerometer for a closed loop feedback and is powered by a Randy Slone 500 Watt amp. The subwoofer amp has an active crossover that splits the sub and satellite signals at line level.
Volume is currently controlled by a bare pot controlling a signal from a Yulong D18 DAC. The DAC is fed by a Squeezebox Touch that gets music at 16 bit/44k Hz by wireless from my computer and an external hard drive.
I would describe the sound of the system as a focused image, somewhat forward sound. That is probably quite different from Bob's Sunflower's which I assume gives a big image, omni speaker feel. It is quite an accomplishment that the FE seems to work very well with a wide variety of speaker types.
My_Ref Fremen Edition - Beta build/Fine tuning ClaveFremen Chip Amps 1523 1st December 2013 11:16 AM
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 03:38 PM
Last My_Ref Fremen Edition RC boards for sale ClaveFremen Swap Meet 3 4th December 2012 01:04 PM
Hx-Home Edition and Hx Mini Edition will be released December, 24th destroyer X Solid State 54 3rd September 2012 03:44 PM
Canton ERGO RC-1 (frequency room compensation) for RC-L - Schematic wanted tiefbassuebertr Multi-Way 2 20th September 2010 11:20 AM
Copyright 1999-2017 diyAudio
