My_Ref Fremen Edition RC - Build thread - Page 19 - diyAudio
Old 23rd August 2012, 10:04 AM   #181
metal's Avatar
Bob, I was not mocking at you when I said you might want to try thermoelectric panels, they come in different sizes and shapes. But first as you have already suggested, is it a valid assumption to control the temperature, may be too much low is not an optimal performance and my idea is false, so how much low you want to go, we wait your results.
Old 23rd August 2012, 10:20 AM   #182
bcmbob is offline bcmbob  United States
I didn't take you comment as anything other than genuine.
I have a computer buddy who is constantly razzing me about when I'm going to start using the nitrogen. He says since it is non-conductive I should just immerse the whole thing and be done with it.
Haven't looked much at thermoelectric but I will.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 23rd August 2012, 10:25 AM   #183
metal's Avatar
Yes, with nitrogen you can over-clock it, and the only bottleneck is then the mechanical HDD Any way, I wonder what results you will get when you start cooling this chip, can you do spectrum distortion measurements while you are maintaining the chip at a specific temperature?
Old 23rd August 2012, 10:49 AM   #184
The further away one can keep a protected/limited chipamp from triggering the protection, the better it will perform on typical dynamic range audio. The fewer clip incidents (that is both voltage clip and current clip) the better the audio performance.
Constant signal distortion measurements will not reveal this "triggering" if you avoid overloading the chip during the testing/measuring.
You are wasting your time doing THD at cool temperatures. It will not show any reduction in clipping incidents in a protected chipamp.
Based on the above a cooled chipamp should clip less often and less severely than a hot chipamp. This leads to my own conclusion. Always run the heatsink and chip as close to ambient temperature as possible for best audio performance.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 23rd August 2012, 10:55 AM   #185
Been watching this thread and hope to use Visual Analizer at some point with the Fremen Edition.
Exploring Visual Analyser (VA)
Bob M.
Old 23rd August 2012, 11:14 AM   #186
metal's Avatar
I don't know if a GB has been arranged before, but it is certainly useful to have one. With a good sound card, this will give you a good measurement system.
Old 23rd August 2012, 11:20 AM   #187
If you are referring to the VA software it is a free download.
Bob M.
Old 23rd August 2012, 11:23 AM   #188
metal's Avatar
I meant the HW. I saw an image for a schematic, I am not sure if this has to be built, as I have not read about it yet.
Old 24th August 2012, 12:48 PM   #189
romvise is offline romvise  Italy
Hi guys, yesterday I've started with the build.
This morning I've tried to power on both channels but the relay don't started on both.
After a check-up i've found some bad join, now both relay and led are working after power on.
Unfortunately channel "1" has some problem, when I try to measure the DC offset I found 60mV and sometime the relay cut the circuit, in this situation the DC offset become 5V!
On C101/C102 I've +/-32.7V.
I've attached two pictures of this channel
The channel "2" has 10mV DC offset so I presume it's correctly working.
Thank a lot for any suggestion.
R.
Old 24th August 2012, 12:57 PM   #190
attach a dummy load, 10k, across the speaker output.
Check the offsets again.
regards Andrew T.
My_Ref Fremen Edition - Beta build/Fine tuning ClaveFremen Chip Amps 1523 1st December 2013 12:16 PM
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 04:38 PM
Last My_Ref Fremen Edition RC boards for sale ClaveFremen Swap Meet 3 4th December 2012 02:04 PM
Hx-Home Edition and Hx Mini Edition will be released December, 24th destroyer X Solid State 54 3rd September 2012 04:44 PM
Canton ERGO RC-1 (frequency room compensation) for RC-L - Schematic wanted tiefbassuebertr Multi-Way 2 20th September 2010 12:20 PM
Copyright 1999-2017 diyAudio
