My_Ref Fremen Edition RC - Build thread
Old 21st August 2012, 12:50 AM   #141
bcmbob is offline bcmbob  United States
You got it right. Just use a file but be careful not to go too far as that will let the leads flop around in the sockets.. Sneak up gradually on a clean but snug fit. Use a very fine file that doesn't remove too much material on a single stroke.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 21st August 2012, 07:39 AM   #142
I should add that the sockets can take only so much manipulation when installed on the board. A preferred method is to use a spare socket off board and fit it over the lead as you adjust the size.
I had better luck using needle nose pliers (on each lead close to the end) rather than fingers for the final insertion on the build. I don't even try to do a swap or rotation without those, good lighting and some sort of magnification.
Bob M.
Old 21st August 2012, 07:47 AM   #143
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Originally Posted by lehmanhill View Post
For you guys that have used these sockets before, what do you do when the leads are too thick? My thought was to file down a short section of lead to fit. Open for ideas. I am hoping to socket and compare C9 and C13
Hi Jac,
as Bob already pointed out using a file you can do it.
But for bigger leads (like C13 ones) PCB mount faston tabs (Mouser 571-63756-1) are a better choice than sockets:
My_Ref Fremen Edition RC - Build thread-dsc_0056-jpg
Dario
ClaveFremen "Bailando Salsa en el Sietch" - For My_Ref FE 12th GB extra boards PM me.
Old 21st August 2012, 04:21 PM   #144
atupi is offline atupi  Romania
I powered up both channels and something is wrong and i cant understand what. Voltage across 3886 and 318 are ok but relay does not click. I dont have CC on output but the voltage acros relay coil is 12 volt. Infact before R14 ihave 24v but after i have almost 12v the same like on relay coil.
R14 is a bit warm.
Old 21st August 2012, 04:29 PM   #145
Is the LED coming on? And are both amps doing the exact same thing?
Bob M.
Old 21st August 2012, 04:36 PM   #146
Yes the error is the sameon both channels. The leds are ON but normally a should have 24v across D4 (diode paraleled with relay coil) but i have only 12v.
I will try to disconect R14 and see if without protection circuit connected i can measure 24v.
LE. Seems that DC protection is hungry. Disconnected R14 and i have 23v before and after. I will take a closer look to the DC protection circuit.
Old 21st August 2012, 04:41 PM   #147
Bill_P is offline Bill_P  United States
The relay needs about 15 volts to activate. Reduce the 470 Ohm resistor to 220 Ohms and try it again.
Old 21st August 2012, 04:42 PM   #148
If and when you have the time, some 90 degree photos of both top and bottom would be helpful.
Bob M.
Old 21st August 2012, 05:00 PM   #149
O.T. Got a reply from Uriah and he is feeling much better and is making good progress in his situation. Let's keep him in our thoughts and prayers.
Bob M.
Old 21st August 2012, 05:37 PM   #150
Found the problem! Someone from Mouser put 0.82k resistors instead of 220k resistors.
Now my relays clicks !
OT Good for Uriah !
My_Ref Fremen Edition RC - Build threadHide this!Advertise here!
My_Ref Fremen Edition - Beta build/Fine tuning ClaveFremen Chip Amps 1526 8th October 2017 03:03 PM
Hx-Home Edition and Hx Mini Edition will be released December, 24th destroyer X Solid State 57 1st June 2017 05:05 PM
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 03:38 PM
Last My_Ref Fremen Edition RC boards for sale ClaveFremen Swap Meet 3 4th December 2012 01:04 PM
Canton ERGO RC-1 (frequency room compensation) for RC-L - Schematic wanted tiefbassuebertr Multi-Way 2 20th September 2010 11:20 AM
