| Chip Amps Amplifiers based on integrated circuits |
#101 |
Andrew
That makes sense. The body is really small. |
#102 |
Would I be ok to use 1R37 Holco in place of 1R for R11.Tia Marra
#103 |
I forgot to order the C34 (27pf) SMD and i must choose between installing some cheap ceramic smd or silver mica caps (non-smd) from PCX that i already have in my drawer.
What would be the right choice ? Last edited by atupi; 13th August 2012 at 06:56 PM. |
#104 |
Reality first!
I would install 0805 C0G ceramics, pads are too small to solder TH SM, IMHO.
Dario ClaveFremen "Bailando Salsa en el Sietch" - My_Ref Fremen Edition GB Second Run |
#105 |
No problem for me to solder a silver mica but will look ugly on the pcb.
#106 | |
It is ironic. I ordered the wrong caps for C10 and got 33 pF SMD mica caps instead. No way to solder the little SMD caps to the TH, so I'm off to Mouser again. I wish these 33 pF SMD would help you, but they are the wrong value and I sense you are in a hurry. Have fun. Jac |
#107 |
Hurry but not so hurry as i discovered that my Lm318's that i already had and not ordered from Mouser is the TI version not National version so i will call tomorrow some stores to see if they stock the National version.
Also i wait for my Mlityc's Ag because i found it at a very good price 12,7EU/pc and ordered 4. |
#108 |
This only proves that I don't really pay attention to something until I try to build it.
Dario, Please give me your thoughts. Why did you choose to use two AC inputs, each with their own diode bridge, but both feeding one pair of smoothing capacitors? What is the understood benefit of 2? Is there a load condition or frequency range that has a bigger advantage? Thank you in advance. I'm sure this has been discussed before, but long before I arrived. Jac |
#109 | |
Nice deal on the AGs. Jac |
#110 | ||
Reality first!
According Suburra the double rectifier gives a bigger soundstage and more refinement. Quote:
Both works but Penasa optimized the compensation on the NS one and strongly suggests use of NS parts.
| Last My_Ref Fremen Edition RC boards for sale | ClaveFremen | Swap Meet | 3 | 4th December 2012 01:04 PM |
| My_Ref Fremen Edition - need help on PCB evaluation | ClaveFremen | Chip Amps | 444 | 29th October 2012 11:38 PM |
| Hx-Home Edition and Hx Mini Edition will be released December, 24th | destroyer X | Solid State | 54 | 3rd September 2012 03:44 PM |
| My_Ref Fremen Edition - Beta build/Fine tuning | ClaveFremen | Chip Amps | 1519 | 16th August 2012 04:05 PM |
| Canton ERGO RC-1 (frequency room compensation) for RC-L - Schematic wanted | tiefbassuebertr | Multi-Way | 2 | 20th September 2010 11:20 AM |
