My_Ref Fremen Edition RC - Build thread
Old 11th August 2012, 07:26 PM   #91
Marra is offline Marra  United Kingdom
Safewash 2000 followed by Saferinse 2000 works for me and leaves the board shiney.
Old 11th August 2012, 09:11 PM   #92
bcmbob is offline bcmbob  United States
Here's my process. I do it after soldering is done and keep the top dry.
JA Pre and MyRef - FE Integration
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 11th August 2012, 09:17 PM   #93
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Originally Posted by lehmanhill View Post
Do you guys try to wash off the tacky flux after soldering?
Absolutely
If you do remove the flux, do you wait until all components are soldered?
It makes sense.
I usually clean two times, the first after SMD soldering and the second after TH soldering.
My though is alcohol and a toothbrush, but I am very open to suggestions.
I'm using a specific spray with its brush but I guess that alcohol and a toothbrush will do.
Dario
ClaveFremen "Bailando Salsa en el Sietch" - For My_Ref FE 12th GB extra boards PM me.
Old 11th August 2012, 09:44 PM   #94
lehmanhill is offline lehmanhill  United States
lehmanhill's Avatar
Another build note. For D4, the Vishay 1N4001 diodes that I bought in the US from Mouser had thick leads. These leads are so thick that they have to be forced through the hole in the board and shave off a little material from the leads along the way.
The next time boards are made, it would be nice if the hole in the board were slightly larger diameter. I suspect that common components like the 1N4001 have a variety of variables like this.
Jac
Old 11th August 2012, 09:49 PM   #95
lehmanhill's Avatar
A little more on the D4 leads.
If you get the same parts as I did, the hole fit will be tight enough that solder won't flow into the hole. I wanted to be sure that I didn't damage the continuity between the top and bottom of the board by scrapping off some of the hole plating, so I soldered the leads on both top and bottom. Thanks to Dario, there are nice solder pads on both sides.
Jac
Old 11th August 2012, 11:49 PM   #96
Reality first!
Hi Jac,
yes diodes' holes are a bit too much tight.
For a more confortable fit leads must be bent with care so that the distance between them is exactly the same of holes.
This is not necessary, the hole plating is strong...if you have doubts simply measure continuity with the multimeter.
Soldering on both sides will result in a much more difficult to remove component in case you need to do some repair job.
Yes, I've updated Eagle files after the first build on green boards.
Dario
Old 12th August 2012, 03:06 AM   #97
TjongKristian is offline TjongKristian
Send a message via ICQ to TjongKristian
Yesterday, I started soldering to board (Thanks Dario for the excellent built of the board and help with the smd parts). I swore that those little smd buggers are alive. They just love to jump like ticks. I got lucky twice with the help of my kids to look for it (They jump out as soon as I open up the packgaging carefully). Looking forward to finish at least a channel by next week.
Old 12th August 2012, 03:14 AM   #98
metal is offline metal  Jordan
metal's Avatar
You need a table lamp It is a good idea to have onw while working with SMD components. Also, open them close to the PCB, they won't start jumping. When you catch them, use a couple of tweezers, not only one
Old 12th August 2012, 09:04 AM   #99
It also helps to do as much of the small stuff as possible in the middle of the bench or table. Don't work near the edege. The reach may be a little uncomfortable - but is helps save the eyes and the knees.
Bob M.
Old 12th August 2012, 11:27 AM   #100
R.I.P.
I think the leads on the 1n400x are thick (consistently thick between manufacturers) is that much of the dissipation is through the leads to the PCB pads, then on to the PCB.
The surface of the diode is a bit small to dissipate much heat by convection.
regards Andrew T.
My_Ref Fremen Edition RC - Build threadHide this!Advertise here!
My_Ref Fremen Edition - Beta build/Fine tuning ClaveFremen Chip Amps 1526 8th October 2017 03:03 PM
Hx-Home Edition and Hx Mini Edition will be released December, 24th destroyer X Solid State 57 1st June 2017 05:05 PM
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 03:38 PM
Last My_Ref Fremen Edition RC boards for sale ClaveFremen Swap Meet 3 4th December 2012 01:04 PM
Canton ERGO RC-1 (frequency room compensation) for RC-L - Schematic wanted tiefbassuebertr Multi-Way 2 20th September 2010 11:20 AM
