Searching chip amp 5-10W
Old 25th July 2012, 04:24 PM   #1
AudioAngel is offline AudioAngel  Germany
Send a message via ICQ to AudioAngel
Default Searching chip amp 5-10W
I'm searching for an amplifier with 5-10W power at 8Ohms. I need analog inputs. I don't care wether it is Class-D or Class-AB both are welcome. Of course sound quality should be good, but the chip should have a good price-value ratio because I need many of them. It is for a line array box where every driver has its own amp. Therefore, less external components would be nice, too.
Do you have any suggestions?
Thanks a lot!
AudioAngel
Old 25th July 2012, 04:50 PM   #2
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
LM1875 will do this with the right supply voltage.
/U.
Old 25th July 2012, 05:12 PM   #3
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
Yes, LM1875 would be a good choice. They can be had for only €1 each.
Old 26th July 2012, 04:10 AM   #4
AmadeusMozart is offline AmadeusMozart  New Zealand
Thanks a lot!
AudioAngel
If the amplifiers are going to be internal in the loudspeaker cabinet then perhaps a digial amplifier might be best since I believe they have less heat generation. Did you take a look at what is available on eBay?
Old 26th July 2012, 04:25 AM   #5
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
TDA2030 has about the best bang for the buck. They go for around $0.30 here.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Searching chip amp 5-10WHide this!Advertise here!
Tiny PAM8610 10W+10W board problems trevmar Class D 29 6th May 2016 02:05 AM
10W amp help Dprasad97 Chip Amps 2 13th April 2012 12:37 PM
10W suitcase amp famousmockingbird Tubes / Valves 16 20th August 2011 05:56 PM
Best possible 10W from chip amp Robert_66 Chip Amps 14 2nd November 2004 11:43 AM
Searching insulator type for LM4780 chip Peter Daniel Chip Amps 10 21st October 2004 12:34 AM
