LM4562 Amplifier?
LM4562 Amplifier?
Old 23rd July 2012, 01:54 AM   #1
aphracer is offline aphracer
Default LM4562 Amplifier?
Hello All,
I am relatively new here but I have an idea of building an amplifier that can drive a pair of 20W, 8 Ohm speakers using an LM4562 or an LM4974 Op-amp. I have done some research and only found that projects that involve a headphone amplifier or a pre-amp but not an actual amplifier using these Op-amps. If I wanted to achieve this do I need a different Op-amp or would I be able to get away with the LM4562 or LM4974?
Thanks In Advance.
Old 23rd July 2012, 12:57 PM   #2
Arty is offline Arty
Opamp Based Power Amp
that is how its done.
the opamp alone will fail to power an 8 ohm load.
it likes something from 600 ohm upwards.
the linked site shows a schematic, use whatever you like opamp.
Most probably anything within regular audio opamp specs will do just fine.
if i was you i would first build the thing with a cheapooo opamp (using ic socket) then if all works as intended simply swap the opamp for something better. IF, that is, if You feel a need for it.
Old 23rd July 2012, 01:02 PM   #3
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
Unless you plan to do this purely for the exercise of circuit building, you will be better off finding a chipamp that suits your needs.
LM4562 Amplifier?Hide this!Advertise here!
LM4562 decoupling... mikesnowdon Power Supplies 32 20th April 2010 08:07 PM
lm4562 is cool! digi01 Chip Amps 8 17th April 2008 02:29 PM
Self on LM4562 sam9 Solid State 7 17th April 2007 02:11 AM
LM4562 instead of OPA2134opa pjpoes Parts 0 15th December 2006 04:01 PM
Lm4562 Ryssen Swap Meet 0 12th October 2006 09:42 PM
