Snubberized LM338 regulated PSU problem
Old 22nd July 2012, 11:06 AM   #1
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Default Snubberized LM338 regulated PSU problem
I've just built my second Carlos FM snubberized LM338 regulated power supply but this time to work with a 30 volt traffo that I had here doing nothing (I used 25 volt traffo last time).
When I completed the regulator circuit, I power it up and everything worked as expected, ie I got the expected voltage from the output. I've used trim pots and was able to vary the voltage by a few volts but settled on 34 volts out from around 42 in.
However, after connecting the supply to the amp and playing for a while ~10 mins (it sounded very good on the test speakers) I checked the voltages again to find that I was getting +/-42 volts instead of +/-34, and both the LM338's had gone short-circuit between the input and output pins.
I've triple-checked the circuit and the actual build but can't find anything wrong. The only two things that I didn't do exactly as CFM's diagram was use .25w resistors for R1 (120R) and R2 (2K7), and to modify the regulator as in the diagram below - which I believe is the correct way to implement these types of regulator to prevent circulating currents.
And here is the CFM diagram.
I've done a bit of searching but apart from FastEddy suggesting that the bleeder resistors should be nearer to 10K than 2K2, and also that R1 should be 910R instead of 91R (which I don't understand as the data sheet suggests 120R), I can't find anything to help me.
Originally Posted by FastEddy View Post
Re: snubbed regulator in your circuit diagram ...
1) I never understood why the value of R1 & R2 was so low in this circuit (2.2K ohms) .... it bleeds off the power supply rails continuously = wasting power and generating heat. (This circuit would fail current production power supply restrictions in Europe and soon, here in the states. = an environmentally incorrect design, etc .... A value about 5 times greater, 10K to 22K ohms would suffice ... or none at all).
2) Likewise, I believe that R3 & R4 should be 910R ohms (instead of 91R ohms) and R5 & R6 should be 22K ohms (instead of 2.2K ohms) ... saving a little more in wasted heat, etc. I would also suggest that for audio work that R3, R4, R5 & R6 be metal film type and held to precision of +/- 2% or +/- 1%. (1/8 watt rating is OK here if R5 & R6 >= 10K.)
3) For capacitors C3, C7, C4 & C8, I would recommend the use of plastic (polystyrene) or comparable "audiophile" quality capacitors ... most especially at C4 & C8. (SoniCaps ?). These capacitors are used here as "snubbing" caps, reacting to and filtering off the higher frequencies and "popcorn" noise associated with fixed voltage regulators and RF from external sources.
4) I always add a Ferrite Bead to the output legs and ground legs of these kinds of linear supplies ... especially if intended for a sperate enclosure. ( Ferrite bead - Wikipedia, the free encyclopedia )
5) Transformer: if independant 30 VAC secondary type is unavailable, then a "center tap", +/- 28 to 30 VAC secondary may be used (although some here might quibble about retaining the "split supply" nature of the original). The center tap can be connected directly to "G" or anywhere upstream of "G" and downstream of the (-) negative LM338 at D2.
6) If output power is expected to exceed ~ 40 watts (output >= 40 VA) ... then a heat sink should be added to both LM338 regulators. If close to the maximum rating of the transformer (200+ VA) then the heat sink(s) on the LM338 should be quite large indeed.
(Alternate part number for LM338 = pin for pin substitution = uA7805, although some here feel that this substitution will be noisier and is of older design.)
And this is the actual regulator in question. The heat-sinks did get quite hot while playing music.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 22nd July 2012, 11:50 AM   #2
Puffin is offline Puffin  United Kingdom
Nick, this is intersting.
When I built my regulated PS's some years ago, I assumed that the heatsinks would get warm, if not quite warm (I just assumed that regulators get warm when regulating). However I have always had stone cold heat sinks. I have wondered if this is normal? Tranny is 30-0-30. If this is a thread crap then I will remove this post.
Rob.
Old 22nd July 2012, 12:07 PM   #3
Nuuk's Avatar
Hi Rob, the heat-sinks with my last LM338 regulators running of 36 VDC also ran cool. I know I was dropping a few more volts through the 'new' LM338s but the heat-sinks did get quite hot. So something is wrong but I just can't put my finger on it myself.
Old 22nd July 2012, 12:12 PM   #4
Nuuk's Avatar
Another question about the LM338 chips themselves. The ones that I have used in the past are marked JM42AC. These new ones are marked JM14RG. Are these just batch numbers?
Old 22nd July 2012, 12:23 PM   #5
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
In my experience LM338 don't go short between in and out from overheating. They protect themselves against that. But they do go short from exceeding the maximum in/out voltage (which is 40V). You have 42V on your supply, so this could be an issue. Also what value caps do you have on adj and output pins? The datasheet recommends protection diodes for 10uF and higher.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 22nd July 2012, 12:32 PM   #6
Nuuk's Avatar
I'm not sure how the LM338's could have dropped more than the 8 volts set by R1/R2. If I am correct, one of those resistors would have to have gone open-circuit for that to happen but they still measure the correct resistance.
The protection diodes are both in place as you can just see in the picture.
Old 22nd July 2012, 12:41 PM   #7
abraxalito's Avatar
The resistors don't control the regulator's drop, they control its output voltage. At start up, depending on how quickly the adj pin cap charges, there can be a very low output voltage with 42V on the input resulting in overstress.
Old 22nd July 2012, 01:21 PM   #8
Nuuk's Avatar
Gotcha! Thanks.
But I wonder why Puffin hasn't experienced the same thing with his set-up? In theory we are using the same circuit.
Old 22nd July 2012, 01:28 PM   #9
abraxalito's Avatar
Seeing as the overvoltage is quite small it could be a number of things that are different. Like Puffin has a smaller adj pin cap, or a lower valued resistor network. Or it could be that in part your overvoltage is made worse by wiring inductance.
Incidentally I notice on your schematic that you say the groundplane ground carries no current. But you have an input cap to the regulator which will route HF currents through the groundplane. Not really so desirable Suggest adding lowish valued wirewound series resistor prior to this cap (say 0R22 - 0R47).
Old 22nd July 2012, 04:59 PM   #10
Nuuk's Avatar
Do you mean as in the top of bottom diagram?
Snubberized LM338 regulated PSU problemHide this!Advertise here!
PCB: LM338 Regulated Snubberized PSU yusuf Power Supplies 7 27th March 2007 01:45 PM
Copyright ©1999-2017 diyAudio
