Old 22nd July 2012, 06:28 PM   #11
Puffin is offline Puffin  United Kingdom
I don't know if this is relevant, but I did not have the required resistor values for a couple of the positions and put two 1/4w metal films in series. Would this give them more power handling? (I think not?)
I would need to open up one of my amps to see which ones these are and to measure the reg modules. If you would like me to do this I will.
Rob.
Old 22nd July 2012, 06:36 PM   #12
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Thanks Rob but I don't think the resistors are the problem. Much more likely it's the start up as abraxalito has suggested. What traffo are you using (I seem to remember it was a 250VA)? Mine is a 400VA and I am wondering if that is the vital difference between our two circuits. I know that some recommend a soft-start for anything over 300VA.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 22nd July 2012, 06:46 PM   #13
My tranny is no more than 180VA (from memory)
Old 22nd July 2012, 06:49 PM   #14
Nuuk's Avatar
So I wonder if that IS the crucial factor?
Another thought I had is that when I tested the regulator circuit, and then the amp for the first time, I used a light-bulb tester. It was when I removed the tester to play music that things went wrong.
Old 22nd July 2012, 10:57 PM   #15
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
Originally Posted by Nuuk View Post
Do you mean as in the top of bottom diagram?
Yes, the top one is what I meant.
The bottom one is useful if you can't afford the voltage drop of the series R but it still lets HF noise pass through the regulator unchecked. If you were to use this case the R should be a normal carbon or metal film, not wirewound. It doesn't need to dissipate much power.
Using the lightbulb in series with the input slows down the voltage rise considerably - it would most likely prevent the condition where over 40V appears across the reg.
When a measure becomes a target, it ceases to be a good measure. C.A.E. Goodhart
Old 23rd July 2012, 08:16 AM   #16
Nuuk's Avatar
Thanks again. It looks as if I would need to build in a soft-start to use this traffo with the LM338's.
Old 23rd July 2012, 08:23 AM   #17
abraxalito's Avatar
You could try something a bit simpler - like a zener diode across the regulator. Say a 1.3W type, 33V. I have no experience of such solutions, but it sounds like it might be worth a try to limit the transient overvoltage.
Old 23rd July 2012, 08:27 AM   #18
Nuuk's Avatar
When you say "across the regulator" do you mean across the input and output pins?
Old 23rd July 2012, 08:32 AM   #19
abraxalito's Avatar
Yes, that's the idea. With a zener between reg 'in' and reg 'out' the output can't easily get more than 33V below the input. The zener voltage could even be much lower, like 12V. Just you'll blow the zener very quickly if you short the output, and the reg may follow very shortly after...
Old 23rd July 2012, 07:22 PM   #20
Just remembered
I use a soft start on my monoblocks (relay triggered)
EDIT: Not speaker protection as originally posted. LS are not wired to it.
PCB: LM338 Regulated Snubberized PSU yusuf Power Supplies 7 27th March 2007 01:45 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
