Old 21st July 2012, 03:17 PM   #1
Default 2 ohm load on TDA1562 with larger heatsink
So I've built amplifier with TDA1562 and it would be great if I could use it with 2 ohm load, unfortunately I can't find any info on how safe it is or isn't. Don't want to destroy the IC, but don't want to buy another one either.
So let's say if I used larger heatsink with the chip (so it's not overheating), can I still damage the IC?
Old 22nd July 2012, 05:18 PM   #2
Yes You can. There is a limit of current delivered.
Getting hot is just one thing.
You can use 2 ohm "safely" as a load if You place a resistive voltage divider at the IC inputs to make sure You do not cross the limit.
(actualy its the same as not turning up the volume.)
Old 22nd July 2012, 06:12 PM   #3
a.wayne is offline a.wayne  United States
a.wayne's Avatar
Can't you run them in parallel ..(multiple chips )..?
Old 22nd July 2012, 06:36 PM   #4
monty78pig's Avatar
I think you'd be ok using a 2 ohm load, but do check the current rating on the data sheet. You can also work out your maximum output power driving such a load by using the equation:
P = I*I*R
Where 'I' is the maximum output current R is the load impedance, and P is the maximum output power driving that load.
Hope that helps
With perfect linearity, it is impossible to go off on a tangent. Also; My Sziklai pairs are better than your MOSFETs/Darlingtons/Pentodes/Triodes
Old 22nd July 2012, 06:47 PM   #5
Well, I tried the 2 ohm load, while I didn't damage the IC, I heard some glitches here and there so I think I'll just buy another IC so I have amp for both speakers (I got 2 speakers each 4 ohm, used them in parallel).
Btw the heatsink is becoming pretty much untouchable even with 4 ohm load, is it fine?
I had bought TDA1562 amp kit and heatsink came with it so I think it should be good, but not entirely sure.
Thanks for replies.
Old 22nd July 2012, 06:50 PM   #6
Boscoe is offline Boscoe  United Kingdom
Try lowering the supply voltage or increasing it to the max the chip can take and put the 4ohm speakers in series.
I thought about it once, but then thought again.
Old 22nd July 2012, 06:53 PM   #7
Boscoe: I'll use it as car amp, so what I get from the battery is what I have.
Anyways, 2 ohms shouldn't be a problem anymore if use 2 chips...
Just worried about heatsink being very hot.
Old 22nd July 2012, 08:51 PM   #8
use a fan maybe?
if it can't be touched, that means its probably too hot.
8 ohm dummy load andrewe1 Parts 43 9th May 2011 05:44 AM
2 ohm load on T-amp 3-LockBox Class D 1 22nd June 2006 12:38 PM
What's the closest I can get to a 4 ohm load using 3 single coil, 6 ohm drivers? The Paulinator Multi-Way 9 11th May 2004 07:04 PM
Zen.4 in a 4 Ohm Load? Rino odorico Pass Labs 8 18th September 2002 02:04 PM
SOZ 4 ohm load cjunk Pass Labs 7 14th March 2002 07:23 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
