Just picked up an SMSL TDA7498 based amp ... to much hiss
Old 21st July 2012, 01:35 AM   #1
Tino is offline Tino  Canada
Default Just picked up an SMSL TDA7498 based amp ... to much hiss
Even with the volume level down all the way, there is too much hiss. Maybe the input sensitivity is very high and thats the result? I notice I'm getting much more output with the volume knob even at 1/4 turn vs my other amps.
Is there any easy way to make the input less sensitive? Say if an amp normally reaches full output at 1V input, to have it so that its full output at 2V instead?
Old 16th September 2012, 01:37 PM   #2
obinse is offline obinse  Indonesia
My 2x100w TDA7498 has just arrived 2 days ago. First listening with this setting:
2 way bookshelf speakers, foobar 2000 on my notebook, i heard that it has hiss....
Then I tried to lower the gain: toggled both the sw2 switch to "on" position.
I will try to add EMI/RFI bead suppresor filter on the power supply path, which it works well to kill noise on my DIY LM1875 amp.
Or try a better PSU. Maybe a car battery can do it best?
Just picked up an SMSL TDA7498 based amp ... to much hissHide this!Advertise here!
Topping TP-20 Mk2 or SMSL SA-S1? kin0kin Class D 4 6th February 2012 03:39 PM
SMSL SA-36 funnies flyinglemur Chip Amps 1 7th January 2012 02:18 PM
TK2050 vs TDA7498 dagb Class D 8 5th August 2011 09:56 PM
Which T-Amp? SMSL SA-S3 or Topping TP21? TylerDurden Class D 1 17th July 2011 02:42 PM
Just picked up an SAE P50 amp... Tino Solid State 2 9th February 2008 08:53 PM
