Scratchy sound coming from tweeter. LM3886
Old 19th July 2012, 09:45 PM   #11
FenderBender11 is offline FenderBender11  United States
Originally Posted by Osvaldo de Banfield View Post
Ok, the other channels work fine, OK, but may be a fake cap in the circuit (For example, the power decoupling, the cap in zobel network, or some RC compensation network) that makes THIS amplifier to oscillate / become unstable, and don't affect the other(s).
Good point but all the caps are genuine. I bought all the parts myself off Mouser.
I might take a look at some of my soldering on the preamp section. Generally my soldering is good, but I remember having a sketchily soldered cap or two because they didn't quite fit right.
Old 20th July 2012, 11:58 AM   #12
Arty is offline Arty
swap channels.
connect the "good" side pre-amp to the "bad" side power amp.
if the pre-amp is the stinky part, you will notice it.
Old 20th July 2012, 12:13 PM   #13
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Here in Argentina (Buenos Aires) there was a time some years ago where some electrolytic caps exploded in the caps drawer, without use.. They were a 105 deg low ESR for motherboards or SMPSīs. The brand Jackon or something like this. Actually we are using Nichicon although costs are higher.
This is to remark that donīt be sure caps are good, measure them although appear to be good.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 20th July 2012, 03:04 PM   #14
I'm quite aware of bad caps. But I used 100% Panasonics on this amp. I'll look around to see if anything looks suspicious though.
Old 20th July 2012, 03:06 PM   #15
Originally Posted by Arty View Post
swap channels.
They're all on a single board, so I can't swap. However, I think I'm just going to use the brute force tactic. Just replace everything that I have a problem with and hope the sound goes away. Maybe I'll get new op-amps too. My op-amps were actually a little weird. I had to replace one actually because it seemed to be a dud. Maybe the other one went bad now.
Old 23rd July 2012, 05:13 PM   #16
johnr66 is offline johnr66  United States
This is where an oscilloscope would come in handy. It could be oscillation with a signal present, such as "bottom side fuzzies" and such. Did this kit come from China?
Old 27th July 2012, 11:49 AM   #17
gmphadte is offline gmphadte  India
Nice wooden box but it may be problematic.
Gajanan Phadte
Scratchy sound coming from tweeter. LM3886Hide this!Advertise here!
Scratchy sound Clubman35 Instruments and Amps 5 6th September 2011 01:28 AM
Scratchy sound Clubman35 Instruments and Amps 0 4th September 2011 09:18 PM
Mission 770 scratchy sound Christowp Multi-Way 8 8th July 2011 11:19 AM
problem - scratchy sound, rythmical adamus Tubes / Valves 10 15th October 2009 08:13 PM
Scratchy clicky noise coming from homemade 6L6 tube amp Jim5150 Tubes / Valves 4 25th June 2009 10:53 AM
