Pls Check PCB for OPA541...
Hi everyone,
I made a non-inverting setup of the OPA541 with a 0.1R/5W Rcl for sensing current. Could you please comment if I have made any mistake or if you have any suggestions please do so.
Thanks in advance!
JojoD
I've got two remarks:
- Shouldn't there be a resistor of 47K/100K from pin 1 to ground to set the input impedance?
-Is the current sense resistor attached to the trace above 'out'? I think it is and that's ok, I just wasn't shure
The rest looks really nice, what program did you use to draw it?
Hi guys!
The pcb works! The 22k was connected at the bottom of the pcb and the grounding was changed to your suggestions.
The 2 amps are powering a 12 inch Targa sub with dual 4 ohms coils (one for each amp) in a vented box. Things around the room are shaking/falling, my wife complains saying the bass is too loud and the windows are rattling :D .
The sound is very good but if you have other suggestions, please do so.
Thanks,
JojoD
