newbi chip amp questions.
Old 26th August 2012, 10:48 PM   #41
iggy18 is offline iggy18
it's okay, you made sure I had the right parts and a schematic on how to build it. I tried a couple of times to wire it up and got it wrong, but I finally got it to work. so I've got the bug. someone should pat you on the back
I was curious about the power supply. I wasn't sure if I needed one because I'm using a battery with this amp and I thought that's what the big capacitor was for.
I'll look around the forum for how to's on building a power supply.
Old 27th August 2012, 05:07 AM   #42
Arty is offline Arty
i will be on vacatio for a week.
Sorthof homework like, look up what is a capacitor, powersupply decoupling, filtering EMI and EMI, how a transformer works.
What is a bridge rectifier, and what it does.
What is RMS voltage value.
These terms can be googled, and wikipedia has good entrys about it too.
Transformers Part 1 - Beginners' Guide to Electronics
allso a good read.
When i get back, is next monady.
Bump this thread up, then we will work out what You need as a powersupply.
So we can build one.
The 9v battery is a verry clean powersource, but since its only 9v, it limits the power of Your amplifier. Out of 9v it can get at best 7 to the output, considering an 8 ohm load that yields 6 watts or so. As of yet i do not know what speakers are You plan to drive with them, but i seen Your threads, seems You are intrested in speaker building.
We can design one later
newbi chip amp questions.Hide this!Advertise here!
Beginner LM3886 Chip Amp Build Questions Dogue Chip Amps 2 24th January 2012 05:14 PM
newbi amp build help sqrivi Class D 4 17th November 2011 10:18 PM
Newbi few questions on Dayton Audio PT2C-8 Planar Tweeter golgiapparatus Multi-Way 2 3rd September 2011 09:56 PM
A few questions about Building a LM3886 Chip amp??? Minion Chip Amps 21 13th October 2006 08:01 PM
A few chip amp questions bigwill Chip Amps 12 13th July 2005 10:30 AM
