TDA2030 for 3w speaker - Page 2 - diyAudio
Old 7th July 2012, 08:45 PM   #11
hi for all,
just another little question, I can't use the solution proposed by Mr KatieandDad (put a resistor in series with the volume control ) because for volume control I intend to use the Toshiba, electronic volume "TC9153", so any help more!!
thanks
Old 8th July 2012, 08:01 AM   #12
yes you can use resistor network.
That ic has an output, and the amp has an input.
What you do is connect the resistorts between them.
why you need that IC for volume controll?
Old 8th July 2012, 08:19 AM   #13
hi Mr Arty
(why you need that IC for volume controll?)
to use a remote control
Old 8th July 2012, 02:48 PM   #14
kroto is offline kroto  Indonesia
kroto's Avatar
Send a message via Yahoo to kroto
Default Voltage divider
Code:
from             to
TC9153           TDA2030
output           input
o═  10k   ════O══o
            │   │10k
              ▼ Signal Gnd
                LowR
attenuation = ────────
             (LowR+UpR)
attenuation about -6dB
Old 13th July 2012, 06:18 PM   #15
thanks 1000 Mr kroto :-)
Old 14th July 2012, 01:04 PM   #16
hi Mr kroto
i have found this links, i think it can helpful:
L-Pad (Driver Attenuation Circuit) Designer / Calculator
3W Tube SE for sale widowmaker Swap Meet 1 14th March 2007 09:15 AM
Source for 3W resistors seve Parts 4 12th February 2006 01:23 PM
3W Pure Class-A AMP DarkHorse Solid State 35 3rd March 2005 06:38 PM
3W instead of 5W in Aleph 5? dantwomey Pass Labs 3 31st March 2003 11:52 AM
Copyright 1999-2017 diyAudio
