HUge dc offset - diyAudio
Old 3rd July 2012, 03:30 PM   #1
Default HUge dc offset
Hello...
Im currently building a lm1875
Im building a dual mono... And im using toroidal transformer 160vac, with secondary output 2x18v
First of all, i was wiring the PSU...and i've got the output is 25V and i think it is great....
The im wiring up my amp.... Without input an output wired on my amp board, i was checkin the dc offset....
And i've got 22V !!!
The im browse any internet, and ive got 2 ways to measuring the dc offset
1. Short the input
2. Put 10 ohm resistor across the output
I did the first way, and got the same result 22v, but not do the second way yet...
Did i just broke my ic ????
Old 3rd July 2012, 04:01 PM   #2
please, schematic of your build, and nice high resolution pictures.
Old 4th July 2012, 01:16 AM   #3
Minion is offline Minion  Canada
You should measure DC offset with a load attached and the input grounded ......
Old 4th July 2012, 01:33 AM   #4
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Not necessarily, you could be missing input ground connection.
Also, adding a load will not affect offset reading.
www.audiosector.com
Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it. - JC
Old 4th July 2012, 04:57 AM   #5
thank you for replying....
is it same thing between loading 10ohm resistor across the output and put a speaker on the output ???
coz i think i just blew up my speaker ( lucky for me, its an unused speaker )
but when i load a speaker... i still got 22v on my output ( measure from + and - at the speaker )
but when i saw peter daniel thread, he has a huge dc too Commercial Gainclone kit- building instructions
but my question is.... i dont know what the function of 10ohm resistor... sorry i'm noob here......
and please find the schematic at the attachment.... i will attach my amp tonight
thank you very much
Old 4th July 2012, 05:28 AM   #6
but when i measure the output... and i dont use the ground from the amp board but from the wall ( nail on the wall )
i've got a tiny dc... its 10mv
Old 5th July 2012, 01:51 AM   #7
gootee is offline gootee  United States
Sorry about your speaker.
Voltages only exist between two points. For the output voltage, your wall ground is not one of those points.
Output voltage must be measured only between the two output connection points (where a speaker would be connected).
NO load should be used (no resistor and no speaker), when measuring output offset voltage.
The signal input should be shorted (connected) to the signal input ground, when measuring output offset voltage. (But I would also measure it when the source device is connected and turned on, but with no signal.)
You should NEVER connect speakers until AFTER you have checked the output offset, and verified that it is low-enough.
Output offset should typically be a few 10s of millivolts, or less.
Old 5th July 2012, 02:01 AM   #8
Have you connected the G- and G+ grounds of your power supply together, at the power supply output, and then connected all of the amplifier grounds to that point?
Old 5th July 2012, 02:17 AM   #9
godfrey is offline godfrey  South Africa
The power supply should give +25V and -25V, total 50V from plus to minus.
Old 5th July 2012, 04:52 AM   #10
@gootee : no not yet.... i was wiring v+ g- g+ v- from power supply to amp board.... haven't do the other wiring... is this the problem ??
@godfrey : yes i mean 25V
i decided to buy a new ic today... and decided to switch the old one tonight.... hope everything going well
Tube preamp huge DC thump! Andypairo Tubes / Valves 42 8th January 2014 07:57 PM
DC offset GregH2 Solid State 35 30th March 2012 03:04 AM
DH-220 Clone (SMART TA-242) can't adjust DC offset using offset bias pot? beady Solid State 6 17th March 2011 10:53 AM
DC Offset JannaCassandra Chip Amps 3 26th July 2008 03:20 PM
Are huge DC blocking caps on Zen ok? Arx Pass Labs 13 3rd November 2003 07:38 PM
Copyright 1999-2017 diyAudio
