Bonzai CMOY.. Dead on One Channel
Old 1st July 2012, 05:38 PM   #11
Humanjava is offline Humanjava  Germany
Checked the caps, even with out caps I should still get the correct voltages..
Took the whole thing apart to double check for cold joints etc. Must be something got killed on the actual board so I write this off.
It would be nice if there was specific areas to test but I guess I will just build it back up on a bread board, which I should have done in the first place. This actual kit is a bit crap in its layout where you are supposed to solder caps and battery leads on a set of jumpers.
Money wasted lesson learned on this one.
IMHO if you are going to design a circuit board there should be no point in jumpers.
Old 1st July 2012, 05:46 PM   #12
kumori is offline kumori  Europe
I thought the same, the board layout seems not be thought through to the end.
Good luck
Old 3rd July 2012, 05:47 AM   #13
Puffin is offline Puffin  United Kingdom
There was a thread a few years ago on RockGrotto.com about these amps. I seem to remember that the power layout was bad in that if one of the batteries died, it could induce DC into your headphones. There was a fix for it, which altered the layout.
Bonzai CMOY.. Dead on One ChannelHide this!Advertise here!
4 channel headphone amp based on Cmoy tomcc Headphone Systems 9 24th May 2011 12:55 AM
Left channel dead doubled Solid State 10 11th April 2010 11:19 AM
one channel chip dead???? joka22 Chip Amps 5 8th January 2009 09:52 PM
So, I finally built a 3 channel cmoy TheSeekerr Chip Amps 11 23rd October 2008 09:15 PM
Dead channel Carlp Tubes / Valves 15 1st February 2007 03:54 AM
