Looking for the right IC for an amp project.
Old 29th June 2012, 11:09 AM   #31
MarianB is offline MarianB  Romania
MarianB's Avatar
Send a message via Yahoo to MarianB
I see you still have much to learn. it's like this:
The amplifier has to drive the signal on both phases, possitive and negative ( think of it as one center line wich is the refference and the signal goes above and beyound that line ), now on a simetricall supply it is easy, the amplifier has both positive and negative voltage to help it drive the signal, but when using a single supply the amplifier first has to split the voltage so that it can have a refference point at the middle from wich it can drive the signal, on both supply config the amplifier has supply rails that it cannot exeed, so on a 12V single supply the amplifier split's it in half, and the SE config has at the output before the dc decoupling capacitor about half the Vin ( 6V for this ), those are the rails for the signal, 6V; now the BJT output devices in the IC need for them selves about .6-.7V to turn on so you are left with 5,4V maximum signal rail possible, and knowing that Pout=V^2/R you do the math.
Old 29th June 2012, 11:20 AM   #32
lazzer408 is offline lazzer408  United States
lazzer408's Avatar
For lack of a better term I'll call it 6v of "bias". If it swings up to 11 and down to 1 (to choose even numbers) then it has 10v p-p of swing. Correct? Everything your telling me I understand. What I don't understand is how 10v can't produce more then 10w. Where are you coming up with it only being able to swing from 1/2vcc and down? Why not up?
Old 29th June 2012, 11:27 AM   #33
MarianB's Avatar
You still don't get it..( damn..am i so lousy at explayning stuff?...)
The term is rail voltage, and it cannot swing upt to 10V and down 1V, it has to swing equally up and down, so it has to split the voltage in half, this example is at 6V, but it will not have a total of 12V peak to peak at the output, it cannot, because the refference point is already set in the middle of that so at the output without the dc cap it can only have +6v or -6V. Now you understand?
Old 29th June 2012, 06:48 PM   #34
lazzer408's Avatar
Yes that's how I understood it in the first place. You said "you are left with 5,4V maximum signal rail possible" Did you mean +/-5.4v? Which is 10.8v rail to rail swing. I used 11 and 1 as my example to keep numbers even. With a 6v center, swinging from 1v to 11v is +/-5v.
I drew this to show my understanding of the output.
Looking for the right IC for an amp project.-sine_wave-png
Old 29th June 2012, 07:03 PM   #35
MarianB's Avatar
It's like this:
The signall allways starts from the refference point wich in this case is the middle 6V, and it only goes or above or beyound that point, but IT CANNOT GO BOTH WAYS AT THE SAME TIME, it can only go UP or DOWN at any time so the signall CANNOT BE more than 6V possitive or negative ( that is above or beyound that refference point ) minus about .6 needed by the bjt's.
If this doesn't helps you either than i suggest a boock for you to read urgently, it is called: The Art Of Electronics, read it cover to cover and you will surely undertand, cus if this does not help you than i give up, and call you a lost cause.
Old 29th June 2012, 08:04 PM   #36
lazzer408's Avatar
That's the same image I just drew. So yes, I do understand how it works and always have. Tell me how (almost) 12v of swing into 4ohm can only produce 10w.
Old 29th June 2012, 08:20 PM   #37
MarianB's Avatar
JESUS!!!!! Excuse the question but...how old are you?...i cannot believe tha someone can be so....well for lack of a better word..close minded...don't you have any imagination?
How many times must i tell you that the actual level of the signal swing can only be about 5,4V? how many times must a tell you that the signal has a possitive and a negative phase and they alternate according to the signal, so even thow the peak to peak level it is about 10V ( or so ), the actual level of the signal swing cannot be more than 5,4V because the swing starts ALWAYS from the middle point and goes either UP or DOWN, it cannot go both ways at the same time, it can only go either possitive or negative from the middle point.
If you still don't get it than stop wasting our time and go to school!!!
Old 30th June 2012, 12:00 AM   #38
lazzer408's Avatar
38
So your saying it only pushes 5.4v then pulls 5.4v at any time. It's not actually pulling the other leg up or down when it's swinging the first unless it's a BTL design. Right?
Old 30th June 2012, 12:04 AM   #39
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
Just give up Marian; don't get frustrated over this guy.
If he doesn't want to understand why single ended output power from 12V is only about ~4.5W (low distortion "RMS", not even accounting for losses) then he can learn on his own.
Just leave him with this.....
Audio power - Wikipedia, the free encyclopedia
Old 30th June 2012, 02:11 AM   #40
lazzer408's Avatar
I do want to understand. That's why I'm asking. If I knew EVERYTHING about electronics, I wouldn't be here. What's a forum for if we can't ask questions? I understand quite a bit about quite alot. Ever think your not explaining it right or leaving out key facts that explain how the output stages work? Grass is green, fine, I got it. Now explain WHY. Just saying 10w is 10w is 10w you only get 10w that's all you get is 10w. Trust me I'm on the same page. How I explain my interpretation may be as different from your understanding as your explination is different from my understanding.
To get back to the ORIGINAL topic. What is THE highest power IC available using the least number of components that can do 2.1 in a single IC...... -or- ......2 ICs using a 2ch BTL + 1ch BTL to make a 2.1 system. Is the TDA1562 my best bet? Are there others you recomend so I can choose? Or do we want to keep arguing over power output?
Looking for the right IC for an amp project.Hide this!Advertise here!
Listen to 6DJ8 Triode through Power Chip IC. Easy project. lineup Tubes / Valves 3 28th April 2011 03:41 PM
search pcb with IC tl494 or other Ic to build a smps caraudio Ground Zero Car Audio 0 13th December 2010 05:58 PM
IR2113 - good driver IC for a first project? Th3 uN1Qu3 Class D 7 12th July 2010 10:52 AM
Th. Lösch Phono Amp: Question about IC used & ECC808 to ECC83 Herr Grau Tubes / Valves 45 23rd February 2009 12:12 PM
Project Tube and ic amplifier PCB or kits Luck Group Buys 9 1st August 2006 04:21 AM
