How do I bridge a OPA549?
Old 14th October 2003, 02:35 PM   #1
JojoD818 is offline JojoD818  Philippines
JojoD818's Avatar
Default How do I bridge a OPA549?
Hi everyone,
I have a couple of OPA549 as samples and wish to build a bridge amp out of them. My purpose would be as a sub amp, nothing special, just want to bridge them for more power.
Any ideas, schematics, procedures are very welcome.
Thanks in advance, regards,
JojoD
Old 14th October 2003, 03:16 PM   #2
hitsware is offline hitsware
www.national.com/an/AN/AN-1192.pdf
See page 5 .............mike
Old 14th October 2003, 03:17 PM   #3
millwood is offline millwood  United States
Account Disabled
would TI be of any help? Like the datasheet or application notes?
Old 14th October 2003, 03:42 PM   #4
JojoD818's Avatar
Default thanks
thanks mike.
So the OPA549 is just an opamp with high output current right?
Best regards,
JojoD
Old 14th October 2003, 04:34 PM   #5
http://focus.ti.com/docs/prod/produc...tNumber=OPA549
Yep ....... Jfet inputs so a little differant than the ubiquitous LMetc. Consider your load before you bother bridging. If you overtax (set off the protection), they don't sound too good.
........mike
Old 14th October 2003, 06:13 PM   #6
JojoD818's Avatar
Default parallel only
In the TI datasheet for the 549, I can only find a parallel setup. This is not the same as bridge right?
My other question is, can I use the application note AN1192 from National to a chip made by TI? I mean can I apply the techniques in the National appnotes to the TI chips?
Thanks!
JojoD
Old 14th October 2003, 06:26 PM   #7
Yes the techniques are the same but the specs are differant for the 2 devices. Same basic circuit should work. (probably better )
Old 14th October 2003, 06:30 PM   #8
JojoD818's Avatar
mike,
Alright! Thanks a lot! At least I know what I'm getting into. If you have any other ideas please let me know.
JojoD
Old 15th October 2003, 06:43 PM   #9
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
have you searched?
this one is nice if you already have a balanced signal
Mads K
Old 16th October 2003, 09:28 AM   #10
sangram is offline sangram  India
For my subwoofer project I got a few OPA 549S chips, and some DRV 134 burr-Brown Line balanced drivers, nice if you only have a single-ended input and want to drive a bridged amp.
There is also a method of using a single resistor to bridge amps, Which I have found degrades sound in some cases and improves it on others. You may want to try this.
In addition if you have a buffer amp capable of driving low impedance ~100 ohms, you could drive one amp from its + input and other through the - input. I do not see any major advantage of doing this over the method explained in the much-quoted AN1192, but it is an alternative anyway.
How do I bridge a OPA549?Hide this!Advertise here!
Reopening an unfinished debate: Dual bridge vs. Single Bridge xiphmont Chip Amps 15 26th February 2008 07:22 PM
OPA549 x 8, bridge/parallel soundNERD Chip Amps 2 14th March 2005 09:50 PM
My latest subwoofer - a bridge opa549 built onto a piece of plexiglass soundNERD Chip Amps 23 13th January 2005 07:56 PM
Bridge OPA549 soundNERD Chip Amps 3 24th November 2004 06:59 PM
Copyright ©1999-2017 diyAudio
