Old 23rd June 2012, 03:52 PM   #21
tsiros is offline tsiros  Greece
tsiros's Avatar
Send a message via MSN to tsiros Send a message via Skype™ to tsiros
yes, that is why it will be vented, top and bottom.
Old 29th June 2012, 03:13 PM   #22
tsiros's Avatar
as of yet:
i've ordered a 120VA 2x18V 3.33A toroidal, four 10mF 50V capacitors (2 per channel, if necessary i'll get more later), two rectifier bridges, the LM4780 and a pcb for it
i'll be giving it +-25V, that's supposedly 30W per channel at 1%THD, i won't be using more than 10W though and usually it will be at 1W.
now i need a <0.7C/W heatsink and the various thingies (caps, resistors, wires, connectors, fuses, fuseboxes, switches etc)
any comments suggestions or warnings would be most welcome!
Old 30th June 2012, 09:31 PM   #23
tsiros's Avatar
I need some help determining the values of Rf and Ri for the amplifier.
are those the usual feedback resistances that determine the gain of an opamp based amplifier?
if so, i might be able to determine their values.
Old 2nd July 2012, 10:33 AM   #24
tsiros's Avatar
I request this thread be moved in the construction subforum
Old 25th August 2012, 10:43 PM   #25
tsiros's Avatar
Ok so maybe my previous questions were stupid or elementary, i don't know...
now i have an other question
What kind (single/multi strand, other), gauge and type (shielded, unshielded, twisted pair, other) wire should i use for the various connections?
  1. from mains socket to power switch
  2. from switch to power transformer
  3. from transformer to bridge rectifier
  4. from rectifier to LM4780 PCB
  5. from pcb to speaker terminals
thanks for any and all input
Old 26th August 2012, 06:49 AM   #26
1 & 2 double insulated mains wiring.
3 4 & 5 twisted pair.
Old 26th August 2012, 11:11 AM   #27
tsiros's Avatar
thanks! but what about gauge and ... strandiness?
Old 26th August 2012, 03:31 PM   #28
1 & 2, maybe 0.5sqmm
3 & 4, maybe 0.75sqmm or 1sqmm
5, 1sqmm or 1.5sqmm
I would use stranded for all. Makes it much easier to do twisted flow and return.
Old 26th August 2012, 04:26 PM   #29
tsiros's Avatar
you've been of great help, andrew, thank you
Old 13th September 2012, 03:38 PM   #30
tsiros's Avatar
ok so i completed it
earth connector is connected to middle of symmetrical transformer and also connected to ground, between the smoothing caps :
-Vcc---)|---GND---)|---+Vcc
however i get buzz. i shouldn't be getting this much buzz. the usb is with ferrite core. the signal wire is high quality shielded.
this, (lm4780) amp has lots of buzz.
the other amp did not have the connection between plug earth and middle of transformer. it was DEAD QUIET.
question: what will happen to the lm4780 if i DISconnect the connection between PLUG EARTH ("E") and MIDDLE of TRANSFORMER, but KEEP the connection between middle of transformer and GROUND on PCB?
Basic & Safe Case/Chassis for chip amp Baztien Construction Tips 16 13th April 2011 08:28 PM
Bridge &amp; Parallel 4 x LM4780 - Basic wiring diagram needed GAH Chip Amps 13 12th August 2009 01:37 PM
MY LM4780 Amp ziling Chip Amps 7 6th July 2007 05:46 PM
A basic chipamp in a not so basic case. waltson Chip Amps 19 24th August 2005 07:40 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
