Hey all.
Not sure if this is the right place to ask, please move it if so.
I am building this Velleman preamp kit and want to swap out the 250k trimmer for a 250k pot and knob. My question is which type do I need... audio taper or linear taper?
Velleman nv
Thanks in advance!
Velleman nv
Thanks in advance!
I can't see a schematic.
But I guess at two alternatives.
1.) if you want to use the pot as a volume control, then use an audio taper pot, also called a log law pot.
2.) if you want to use the pot as a sensitivity control, then use a linear pot. That way you can set to 50% or 10% by estimating the rotation angle as a proportion of the total adjustment angle (usually about 270degrees).
You could put the 1 Mohm pot in parallel with a 330 kohm resistor. This will create a ~250 kohm pot with a non-linear taper. The non-linear taper could be a good thing since this is a gain control. It will provide a more natural feel when adjusting than a simple linear pot.
A pot in the feedback loop of an op-amp will be very sensitive to lead wire length. Try to keep the pot's wires as short as possible.
2-3"s is that too much?
- Chip Amps
- Swap 250k trimmer for 250k pot?
