Issue with Arjen Helder monoamps and minidsp
Old 19th June 2012, 09:06 AM   #1
viktor89 is offline viktor89  Denmark
viktor89's Avatar
Question Issue with Arjen Helder monoamps and minidsp
Hi all
I am having some problems with my amplifier & minidsp and I was really hoping to get some help here.
I have connected my minidsp with 2 arjen helder monoamps (these: PAIR OF MKII STA508 Tripath 100W monoblock amplifier | eBay )
I have tested each amplifier seperately - works fine. I have tested the dsp with a Muse M20 EX2 amp - works fine.
I have attached a screenshot of my setup.
When I power it up, i just get a continueous "noise". Best described as a windy sound - kinda like when you put your ear to a conch (just louder, though). I do not understand what could be wrong... Any suggestions?
It seems as though my amplifiers doesn't "understand" the minidsp signal, but has no issues with a direct signal from ipod/iphon/etc
The box in the top right corner is a 12v - 24v dc-dc converter (this one: 240W Car DC 12V to DC 24V Step Up DC DC Converter ! | eBay )
Thanks in advance!
Old 19th June 2012, 11:24 AM   #2
Arty is offline Arty
Can You borrow some batterys to test the setup without that step up converter?
that looks fishy to mee.
Old 19th June 2012, 11:31 AM   #3
viktor89's Avatar
I could test it in 12v? Would that do?
Old 19th June 2012, 08:46 PM   #4
sure, if the amps and dsp can run on 12v , then its fine.
battery power would be the best.
then test dsp on inverter, amps on battery.
then dsp on battery and amps on inverter.
this will help find out what is the problem.
Old 19th June 2012, 08:55 PM   #5
curryman is offline curryman  Germany
Seems like you are setting up a car Stereo. You should use the miniDC Isolator to avoid any noise problems from car electronics and inverter.
With respect to your Setup maybe stray field from the amplifiers can cause some noise in the miniDSP. Did you try moving the DSP away from the amps?
Send with Tapatalk from my Defy+
Old 21st June 2012, 09:43 AM   #6
viktor89's Avatar
It is not being used in a car.
I tested without the converter and I have no sound at all. I also tried using 24 v on the entire setup - still no sound. I will do some more testing according to the suggestions tonight. Anybody got more suggestions for tests that I should run?
Old 21st June 2012, 06:35 PM   #7
yes, try the amps on battery power without the mini dsp, seems they might be FUBAR
Old 21st October 2012, 09:18 PM   #8
stenak is offline stenak  Norway
Default Helder STA 508
I have a pair of the Helder STA 508. Think I going to use a smps 24v/6A for both channels. Should I buy a transformer with two 18v windings, some Rectifier Bridges , and a couple of Rifa 4700mF on each channel instead?
[Review] Helder HiFi STA508 Monoblock amplifier - [English]
Old 27th October 2012, 08:04 PM   #9
look up a tipical gainclone psu and copy it.
most probably you are going to be better with that.
Issue with Arjen Helder monoamps and minidspHide this!Advertise here!
Arjen Helder Buffer V2 Zero One Class D 72 19th May 2013 12:45 AM
Arjen Helder tube pre on ta2020 and maybe a MINIDSP? JOHNNYFAMOUS Class D 23 25th August 2012 01:47 AM
Good Experience with Arjen Helder mfong Class D 6 10th May 2011 07:07 PM
Arjen Helder amp for TV Kjeldsen Class D 2 6th April 2011 05:43 AM
Where is Arjen Helder steveww Class D 6 5th October 2010 06:32 PM
