lm4780 crossover distortion at higher output levels
Old 17th June 2012, 06:15 AM   #1
routhun is offline routhun  United States
Default lm4780 crossover distortion at higher output levels
I just finished lm4780 amplifier based on PCB designed by Veteran. Although original PCB is for parallel operation, I am planning to use it for stereo configuration. I am encountering some weird distortion, at moderate to higher output levels. At lower levels (output is less than 500mv) there is no distortion, but it starts afterwards and stays like that. I am thinking it might be due to some oscillation, but not sure. Will post the pictures soon, anyone encountered such an issue?
Thanks,
routhun
Old 17th June 2012, 06:21 AM   #2
Here is the sinewave output.
routhun
Old 17th June 2012, 07:34 AM   #3
Mooly's Avatar
That looks to be just lack of forward bias but is that even possible with that IC ? Oscillation would show as a thickening of the trace.
I wouldn't discount physical wiring layout/grounding scheme/arrangement too without seeing it all first hand. Is the IC running hot.
lm4780 crossover distortion at higher output levelsHide this!Advertise here!
low crossover-distortion class AB output stage topologies capslock Solid State 72 10th May 2013 08:48 PM
LM4780 heavy distortion at low levels ra7 Chip Amps 26 16th June 2010 01:32 PM
Higher-harmonic distortion canceller jkeny Solid State 0 30th January 2009 12:39 AM
Higher order crossovers is it possible with LM4780? diysmartdeep21 Chip Amps 0 10th February 2005 01:17 PM
Measuring very low levels of acoustic distortion Kevinbd Multi-Way 1 23rd April 2003 05:35 PM
Copyright ©1999-2017 diyAudio
