Gain-clone works on 12v
Old 13th June 2012, 04:58 PM   #1
jacobsetti is offline jacobsetti  India
Default Gain-clone works on 12v
Hello every one
can somebody tell me the chip amps that works on single 12vdc
Old 13th June 2012, 06:19 PM   #2
macboy is offline macboy  Canada
I have built a LM1875 that runs on 12V. At merely 12V, you can easily bridge the output of two LM1875, even into 4 ohms. This also eliminates the need for an output coupling (DC blocking) capacitor, normally needed for any single supply power amp.
If you power it from car's electrical with the engine running, it will be more like 14V, and that little extra voltage can make a big difference.
Old 13th June 2012, 07:24 PM   #3
Is there any PCB for that?
Old 14th June 2012, 01:14 AM   #4
Minion is offline Minion  Canada
I believe a TDA2005 would work ...... Its a stereo chip that can be bridged and is used in car audio applications , It think it is a 2 x 10w chip ......
Old 14th June 2012, 06:31 PM   #5
johnr66 is offline johnr66  United States
The TDA2050 will give you about 2-3 extra watts because it can swing closer to the rails than an LM1875. Still, these ICs that can have up to a 50 to 60 supply voltage are not optimized for output swing like the BTL chips that are meant for low voltage car stereo use. TDA1558Q and newer ICs give you two BTL amps in one package and need minimal parts thanks to fixed gain and modern design.
Gain-clone works on 12vHide this!Advertise here!
Gain clone testing stcboy Chip Amps 3 2nd August 2008 04:27 PM
New gain clone transformer Ted205 Chip Amps 1 8th July 2008 02:24 PM
Simple 12v gain stage dublin78 Solid State 10 14th April 2008 04:37 PM
mutt clone in the works jaudio Multi-Way 28 1st December 2006 11:01 PM
What is a Gain Clone exactly? Lars Clausen Chip Amps 33 26th November 2003 06:33 PM
Copyright ©1999-2017 diyAudio
