About TDA7250/TDA1514A
Old 12th October 2003, 05:08 PM   #1
MaXiZ is offline MaXiZ  Italy
MaXiZ's Avatar
Send a message via ICQ to MaXiZ
Default About TDA7250/TDA1514A
Is there someone experienced or that have already build a power amp based on TDA7250 or TDA1514A that can givemesome tips on the most important thing to check and how many power is needed to make it at least run? I own a SMPS +/-35V@2.5A..
Old 12th October 2003, 06:00 PM   #2
JojoD818 is offline JojoD818  Philippines
JojoD818's Avatar
I have built and used a TDA1514A powered by a 18V-0-18V@10A transformer and 4pcs 4,700uf per rail (8 in total). I have used it for awhile and have excellent result. Later I used it to power 2 10" sub in a push-pull config. Excellent result again.
So good that a friend bought it! An example of a diy hobby that makes you some money for more diy hobby!
Hope this helps,
JojoD
Old 12th October 2003, 06:01 PM   #3
JojoD818's Avatar
BTW, I think this thread belongs more appropriately to ChipAmps.
JojoD
Old 12th October 2003, 06:42 PM   #4
MaXiZ's Avatar
Did it really need so much power? 10A????
ANd could u post the schematic u used for build so good amplifier?
Old 13th October 2003, 04:16 AM   #5
JojoD818's Avatar
Default schematic
this is what i used. you can omit the caps between the rails if your psu is good enough and placed close to the ic.
Old 13th October 2003, 04:19 AM   #6
JojoD818's Avatar
Default 100w bridge
a bridged 1514A
Old 13th October 2003, 09:25 AM   #7
mcp is offline mcp  United States
Default TDA7250 Amp
Hi MaXiZ
You are almost there with your TDA7250. It will work with +-35V. Though 2.5A is not enough for maximum power output, it is not an immediate problem as you don't need the power now. What you want is to get the amp to work first.
Are you using TIP142 AND TIP147?
Here are some pictures on how I tested the TDA7250
Michael Chua
Old 13th October 2003, 09:55 AM   #8
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
The TDA1514A is an excellent chip (praise indeed from a valve/tube man ) I've been using them in products for several years. I've used the Philips circuit, and the results have always been good.
Enjoy.
Thread moved to Chip Amps Forum.
Old 13th October 2003, 10:48 AM   #9
Yes, I agree. The funny part is, when I ran it at 18-0-18Vac, instead of 20-0-20, it sounded much better. I heard that this part is now discontinued. It would be a shame if it is.
Michael Chua
Old 14th October 2003, 07:41 PM   #10
MaXiZ's Avatar
And what's the optimum supply?
I mean Voltage/Current!!!
About TDA7250/TDA1514AHide this!Advertise here!
Exploding TDA1514A problem mobyd Chip Amps 2 15th March 2008 06:40 AM
.. are TDA1514a **** or what ..?? tmyr Chip Amps 1 1st December 2006 08:06 PM
TDA1514a amp jez Chip Amps 5 17th April 2006 09:19 PM
Cambridge a1 MK3 TDA1514a chip katanassn Chip Amps 5 15th November 2005 10:06 PM
TDA1514A Mute/Stby? Dxvideo Chip Amps 4 9th October 2005 11:00 AM
