About TDA7250/TDA1514A
Old 15th October 2003, 05:13 AM   #11
mcp is offline mcp  United States
Default Transformer for TDA7250
Use a 27-0-27Vac transformer with a 200VA rating. This will be enough for 2 channels.
Michael Chua
Old 7th December 2003, 06:55 AM   #12
dave_ryman is offline dave_ryman  United Kingdom
Question Having trouble designing a power supply for the tda1514a
Glad to know that the TDA1514a is getting some rave reviews, because I've chosen it in a design I'm working on for a 5-channel power amp for my PC (left, right, 2xrear + centre).
The 10A quoted in an earlier post is based, I think, on a website which suggests providing 5A per TDA1514 chip. I suspect this is overkill. I started on this assumption for my 5 channel amp, and ended up having to buy a nuclear power station just for the power supply.
I am now working on the assumption that the power requirement is 1.5 x (output power) - from another website (cannot remember that one, either ). I am planning on powering the amp with +/- 22v. Therefore, I am assuming that 2A is more than enough for each amp, and that 10A enough for my whole project. If anyone knows why this is not a good set of assumptions, please let me know!
I'm going for a +/- 22v supply for a couple of good (or so I thought) reasons. First, it is below the maximum allowed in the datasheet for both 8ohm and 4ohm operation, so I don't need to switch the voltage down if the speaker is changed. Second, it is close to the maximum voltage, so I get the maximum output from the amp - is this correct? What affect is there on the chip by running at lower voltages?
My big problem ATM is the power supply. I'm planning on rectifying the output from a 2x25v transformer (toroidal), and then passing this through a voltage regulator. Problem is building a voltage regulator tough enough. I've seen a posting (http://www.pclincs.co.uk/Forums/showthread/t-293.html) which shows how to use an ordinary (1A) regulator together with some power transistors to deliver a high current. I have this in mind as the solution to use. Having worked out how to get a variable Voltage regulator to deliver 22v @ 1A, I am not sure now of the component values to use.
I believe I want a regulated voltage supply, to avoid odd effects in the amplifier when the unregulated supply wanders around.
Some help and advice in resolving my power supply problems would be really appreciated - thanks in advance
About TDA7250/TDA1514AHide this!Advertise here!
Exploding TDA1514A problem mobyd Chip Amps 2 15th March 2008 06:40 AM
.. are TDA1514a **** or what ..?? tmyr Chip Amps 1 1st December 2006 08:06 PM
TDA1514a amp jez Chip Amps 5 17th April 2006 09:19 PM
Cambridge a1 MK3 TDA1514a chip katanassn Chip Amps 5 15th November 2005 10:06 PM
TDA1514A Mute/Stby? Dxvideo Chip Amps 4 9th October 2005 11:00 AM
Copyright ©1999-2017 diyAudio
