Another "can I use this transformer?" thread
Old 26th June 2012, 03:50 PM   #21
rodolfo is offline rodolfo  Mexico
silver1omo see you inbox please
Old 26th June 2012, 04:41 PM   #22
AudioSan is offline AudioSan  Norway
this is a 4x21V + 2x15V transformer. two and two sec. are internaly wired in series.
then you get 2x42V and a midpoint betwin the sec. where you get 2x21V
black is sentertap. the blue-black wires are the midpoint betwin those 2 sec. red-black wires are 2 sec in series
Old 26th June 2012, 05:01 PM   #23
silver1omo is offline silver1omo  Mexico
Thanks AudioSan, that was my guess, and really needed confirmation
Old 27th June 2012, 03:07 AM   #24
What do you think of separating the secondaries to get 2x 21v-0-21v?
Old 27th June 2012, 03:44 AM   #25
gootee is offline gootee  United States
It looks like maybe it was made for that.
What does the PCB tell you about that?
And what does it tell you about current capacities?
Old 28th June 2012, 10:11 PM   #26
I no longer have the amp PCB... The AC PCB has a 4A fuse (T4AL250) and the amp PCB had a couple of 5A fuses (T5AL250).
Old 28th June 2012, 11:41 PM   #27
no. that will require opening up the transformer and cut the winding at the centertap and split it in two.
Old 28th June 2012, 11:54 PM   #28
I took a close look, won't need to cut the winding, just de-solder a pair of wires.
Old 29th June 2012, 12:05 AM   #29
okei. so there is 4 sec. solderd togheter on terminals on the bottom of the transformer?
in that case, it's all good
Old 29th June 2012, 12:34 AM   #30
One red, one blue (pair of wires) and one side of the black (pair of wires) are a yellowish emmanel wire the other red, blue (pair of wires) and side of the black (pair of wires) are redish emmanel wire.So it looks like it does have 4 secs and can be split to 2 center tapped 21/0/21.
Another "can I use this transformer?" threadHide this!Advertise here!
diyAB Amp The "Honey Badger" build thread Variac Solid State 2983 7th January 2018 04:08 PM
SymAsym - "The Sequel", AAK's Rev_1.4 PCB Builders Thread AAK Solid State 161 19th December 2016 10:23 PM
SymAsym - "The Sequel", AAK's PCB Builders Thread AAK Solid State 225 7th September 2015 05:03 PM
a thread for "resto-mod" turntables...(administrators/moderators please read) Nanook Analogue Source 26 15th February 2012 01:19 AM
"compact loudspeaker factory visit from "magico mini" thread Nanook Multi-Way 2 4th January 2008 08:30 AM
