| Chip Amps Amplifiers based on integrated circuits |
#31 |
to check that. you can massure resistance from red to red. and from red to the solder point you think is the centertap solder(there you think you can desolder it). and see if the resistance is half of the resistance from red to red.
aleph P1.7 pre. F5 power amp. CDpro2(need DAC). Vivaldi8 speakers |
#32 |
I have the same issue now
trying to remove a 120-220-240V mains selector switch tricky, but with 3 voltages and only 4 wires I reckon it have to be one wire with taps will try and see what happens if I remove a wire from the switch |
#33 |
did you test with the leads disconnected to the board? if that is the case then the primary is easy, just use the blue and the orange wire and you're done...
http://www.elab.ph/forum/index.php?topic=32688.0 |
#34 |
ok, before cutting I measured 450ohm at 240V mains switch
after cutting the blue wire from selector, still measure 450ohm and 220V is gone from selector seem fine so far |
#35 |
checking secondary voltage, and still 19-0-19V
cutting the red wire, and measure 450ohm on main switch power on and voltage check and still measure 19-0-19V
#36 |
good job....
#37 |
thanks
not so easy to find nice small trafos these days |
| diyAB Amp The "Honey Badger" build thread | Variac | Solid State | 309 | 20th May 2013 03:10 PM |
| SymAsym - "The Sequel", AAK's Rev_1.4 PCB Builders Thread | AAK | Solid State | 137 | 31st December 2012 02:39 AM |
| SymAsym - "The Sequel", AAK's PCB Builders Thread | AAK | Solid State | 219 | 3rd June 2012 04:21 PM |
| a thread for "resto-mod" turntables...(administrators/moderators please read) | Nanook | Analogue Source | 26 | 15th February 2012 12:19 AM |
| "compact loudspeaker factory visit from "magico mini" thread | Nanook | Multi-Way | 2 | 4th January 2008 07:30 AM |
